H14 Shroud anchor points
I'm interested to know if anyone has an opinion on moving the shroud anchor points from the Tramp. side rails, as they are on my 14', down to the hulls, as they are on a 16'. I wonder if there is any advantage or dis-advantage to this. In my mind it seems like it would be a stiffer setup.
Also are you useing a trapeze or not?
Back before the trap was legal on the cat rigged 14 the best way (fastest) to hike up wind was with your back leg on the tramp (foot under the hiking strap) with your inner thigh against the back of the stay and your fwd knee on the hull between the deck and the tramp beams. This got your weight right where it needed to be. If you're still sailing without a trapeze moving the stay would mean hiking in the
wrong
place.
Matt's reason is better though. Don't do it, you'll wreck you boat.
I added anchor bolts to my 14 by drilling a hole in the hull lip and then using a 16/17 anchor bar for support. It adds to the strength of the side bar, but does not replace it. I used the bow tang from a 16 for the upper bracket. I have a hand swaging tool, so I swaged the wire while it was on the boat.
- 3,124 Online
