H16 hull tremplate
Hobie 16 Forum
1
Posts
1
Users
0
Reactions
3,950
Views
I am very confused about the use of the H16 hull template. I'm using a 8 1/2 X 11 piece of paper I downloaded. It has hull bottom templates for the 14, 16, and 18 on it. There's a scale across the top that I assume is to properly size the template after downloading. (I used a copier to enlarge it.)
The text seems to indicate three places to use the template: at the fore and aft pylons and right in the middle. It's not even close on the pylons. Are you only suposed to check the shape in one place between the pylons? Is there some other scale I need to know about to get the template to fit the other cross sections?
Thanks.
Posted : July 13, 2009 8:03 am
Forum Information
- 2,951 Online
Our newest member: TooTallTom
Latest Post: Hobie pearl / tiger mast needed
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
