Hardware on a 16 - which is better
I have two 16's one is OLDER - (bought used cheap) has Harken blocks/hardware. Looks really nice - works fine.
NEWER boat I also bought used recently has other hardware. SEAWAY I think is the name on it. Has very light rust (could be rubbed off easily I'll bet) looks okay, performs well...
The difference is this set has some sort of rachet above the travel car that I REALLY LIKE - (love the sound has I haul in the main sheet). I might sell the older boat, but I want to pull the best parts from it for the newer boat.
Which hardware would be superior? (better to have on the best boat). I'd hate to sell the old boat with the Harken gear if the Seaway gear is junk in comparison? I really have no clue.
Maybe both are same quality?
I would say that since Hobie now uses all Harken blocks on their new boats, that Harken is better. Then again, can you have too many spare parts? I have a harken 6:1 mainsheet system, which you will eventually want as well if you don't have. I can send a pic if you'd like. I like the ratchet in high winds, in the lower stuff I turn it off.
http:/
Thank link has a pic of my 6:1 blocks. I wouldn't say that the 6:1 is massive. It is designed to be
low profile
. In my opinion, the ratchet makes it a little easier control the main with the mainsheet.
If the ratchet is off, the block will spin freely.
This will allow you to either let the sail out really fast if the ratchet is off.
or
Will help with sheeting in if the ratchet is on. The block will only turn in one direction, so there is some friction on the line.
I can almost sheet one handed in light air, but then I run a slightly fatter line.
- 3,343 Online
