Harken help
Sonny Harrison
(@streetdoc432)
[#12776]
I have a Hobie 16 with the stock main traveler car. I just bought a used Harken mainsheet system. The mounting pins on the blocks have a 1/4" pin, the traveler car has a 3/16" pin. Is there a special shackle I need to buy, or is there an adapter plate for the traveler car?
Posted : October 27, 2003 10:47 pm
(@Anonymous 2522)
Put a shackle with a 1/4" pin on the end of the block, and a 3/16 pin through the traveller car with the shackle between the two sides of the traveller. See the murrays catalog for a pic of the block with shackle.
Posted : October 27, 2003 11:53 pm
Sonny Harrison
(@streetdoc432)
Thanks for the advice, I'll give it a try, I just thought putting a shackle around the 3/16 pin would bend it in heavy wind...Have a Hobie Day!!!
Posted : October 28, 2003 7:50 pm
Jules_topcat
(@Jules_topcat)
I had the same problem and i have never bent or broke a shakle so dont worry!!
Posted : October 28, 2003 9:21 pm
(@Anonymous 2522)
I use a stamped 'D' shackle on mine, if you go to west marine or check the catalog you will see one. It is stamped from a flat piece of stainless with a clevis pin. It is plenty strong enough but also has a flat profile so the load on the 3/16" pin is not at one point but spread out a little.
Posted : October 28, 2003 9:59 pm
(@_removed-account)
Four Star Admiral Registered
If you’re going to race your boat don’t use a shackle. Due to the excessive mast rake carried by the 16 when racing you want to limit the distance between the boom and the back beam. That means low profile blocks and no room for big shackles. Attach the harken block directly to the traveler car with the 3/16 pin. You will need to bend open the traveler car a little bit. That’s how the fast guys do it. I’ve had mine rigged up like this for a few years and never bent the pin.
Posted : October 29, 2003 9:34 am
(@Anonymous 32191)
I connect mine the same way,only what i did was file the post on the block down a bit instead of bending the traveller car attachment.
Posted : October 29, 2003 1:40 pm
