Harnesses and Hooking In
I have a few questions about tapering and harnesses. I’ve done searches and have found many answers to questions but I still have a few.
I've mainly been looking at the Murray's catalogue: http:/
I also need to get a new harness; the one that came with my boat is well from the dark ages. It's a butt bucket with shoulder straps. I really have no idea what kind to get. I know I won’t be going with a “nappy” style, just looking at the design of these it is clear that as a guy they’re not going to be comfortable. Do you guys have any opinions about the “Gul” harnesses? I think I want a full harness for the back support, but is a full harness comfortable to just sit in when not trapped out? Does any one know of any places in Northern Cali that I could go to try them on?
Thanks in advance for all of your help.
Adam
Adam,
I'm sure there are people out there that have used either of these or if you know of something else that is better. -I have not used both, only the hook and quick release hook.
I think I'm leaning towards the key hole system (Item G) because I feel it's safer than the hook. -With a load on the attachment point, in an emergency situation, the quick release would be easiest and the safest.
I'll probably end up punching a hole in my hull, or tearing the tramp with the hook. -Always a possibilty, a hook is inconvient when pulling yourself back on board after a capsize, in that I'm wanting to twist my hips to one side while lifting myself up to avoid contacting the hull with the hook.
I know I won’t be going with a “nappy” style, just looking at the design of these it is clear that as a guy they’re not going to be comfortable. -My oldest son (mature) and I both prefer the nappy harness. We have an older harness with the leg loops and both feel uncomfortable in it, compared to the nappy. The spreader bar eases the hip squeeze, but can be uncomfortable while sitting or crawling. Our nappy's are one size larger than "perfect" allowing adjustment in the straps to get a proper "home" for the spreader bar.
No help since we're not in your area, but yes, definetly go try stuff on.
Hmmm.... I use the "can't miss- style" handle. They are very popular among sailors. Most actively sailed boats in my area use this style.
I also use a spreader bar - but not the stuff that Murrey sells. I use one that is designed for windsurfing. Most of those do not have pointy hooks - less of a risk to cause damage to gel coat and tramp.
I have used the keyhole style system - It is nice and works well. I do not own it because it is expensive.
I have not used the quick release system - It looks like a nice system for lots of $$$'s. In the future this might be a requirement if you sail in a competitive way. Research the Hobie class rules - IIRC there is something about the need for a quick release between harness and wire.
Harness... check those out http:/
Safety... In a capsize situation you will be able to unhook. I would be more concerned about pitch poling situations where you might get tightly wrapped around a shroud or the other trap wire. The bad news is that the quick release might not fix that problem depending where or what is tangled up.
Patrick
Adam
I just bought a Gul Pro harness (non nappy) at the end of the season so I only got to use it once or twice. It has a built in spreader bar so there is no additional expense there unless you get the keyhole system. It is easy to adjust and reasonably comfortable (relative to the butt bucket I was using before). The lumbar support is made of foam, which is to say, not much support at all. I guess that is a trade off. A stiff back support would be awful any time you are not out on the wire.
- 1,326 Online
