Interlux vc-17 and primer
Well i finally want to do soemthign about my hull. I already do what your not supposed to do and keep it moored in the water. Blisters have started to form and paint has started to peel from the hull below the water line(previous owner may have painted it). I did a little research and the best and easiest thing to do is use interlux's VC2 Tar as a primer and then finish with the VC-17 antifouling paint. My plan was to mask off a line a little above the waterline and refinish it from there down. Is this a good idea? I dont want to get into anything more complicated than that. Also on the bottom it is almost down to the fiberglass it seems in some spots(mostly scratches, no big areas). Will the primer and paint take care of that?
http:/
http:/
thanks for the input, and please steer me in the right direction! I have no experience with this at all.
- 1,687 Online
