leaking hull repair
32.2 K Views
(@Anonymous 38896)
[#15654]
I've had my hobie cat 16 for a long time and I never got around to maintaining the hull bottoms. Now after beaching it all the time and whatnot, they have worn down and one of them is leaking. I've read alot about different methods of repairing the hull bottoms but I'm not sure which one applies to my situation. I'm including a picture of one of the leaking spots on the hull that leaks with this post, then the next will be the other leaking spot, and the third will be a picture of the other hull, which is not leaking but still worn down.
Posted : June 18, 2005 11:44 am
(@Anonymous 38896)
here's the second leak spot. it's not quite as bad as teh first.
Posted : June 18, 2005 11:46 am
(@Anonymous 38896)
this is the bottom hull. it doens't leak yet, it looks like the previous owners put something on it.
Posted : June 18, 2005 11:47 am
Jim
 Jim
(@jaimezx)
Definately needs some work. There are a number of posts on bottom jobs; do a search to get some ideas and then we'd be happy to answer specific questions.
Posted : June 18, 2005 8:31 pm
(@Anonymous 38896)
so with the boat over on it's side I couldn't really get to anything so I went ahead and took down the mast and flipped it all the way upside down. Since no matter what I do the are where i'm gonna be applying stuff is gonna have to be sanded, i went ahead and did that. On the damaged hul while I was sanding I hit a few weak spots and one crack. The crack is pretty thin but some of the material around it it damaged as well. I have read about sticking a hacksaw into the crack and using it to cut away the damaged material, but I'm reluctant to make the thing any bigger. Also, there is alot of controversy about using epoxy vs marine tex vs polyester resin and whatnot. I think i'm pretty sure for this one I wanna actually add some chopped fiber material though. In all the posts I have read people usually talk about mixing chopped fiber with something else (like polyester resin) but when I went to west marine to look around the only thing I could find with chopped fiber material was already in some kind of liquid. Anyway, I basically want to repair it with something that will hold up structurally, but will also be waterproof (some of the fiberglass structural fillers were not waterproof). What exactly should I use for this?
Posted : June 20, 2005 8:09 am
(@dpcarey)
Aaronhoy,
Look a few posts down for "Hull Condition". I posted a detailed step-by-step on how to fix this very problem. As for the chopped glass,yes find some and mix it into the resin to fill some of the voids. However, this should not be your first step, nor should you neglect to use some fiberglass cloth in your repair. As for the resin controversy, go with epoxy for sure. This will (by far) adhere the best to the damaged area. For this job, polyester resin is simply a poor choice. See the post as I suggested. If you have any other questions email me at dpcarey@golden.net and I will help you out. In the mean-time,dry those hulls out and keep the rain off of them until the repair is done.
Posted : June 20, 2005 1:19 pm
(@Anonymous 38896)
wait, so the stuff I found that was some chemical with fiber in it is what your talking about when you say chopped fiber? or will this be literally JUST chopped fiber material?
Posted : June 20, 2005 2:10 pm
(@dpcarey)
There are some products available with glass fibers already mixed in. However, I have always prefered buying the chopped (usually called "milled", not "chopped") fiberglass separately and mixing it with the resin of my choice. That way you can completely control the viscosity of your mixed product. This is important for different applications at different temperatures. Also, and perhaps most important, the pre-mixed stuff that I have seen has been mixed with polyester or vinylester resin. And although I generally like the vinylester resins, I do not like polyester for structural repairs. For structural repair, epoxy is the best way to go. Vinylester is nice for smaller stuff (chips, dents, dings and scratches) especially if you are on a tight budget. Also, the chopped (milled) glass, when mixed thick with resin, can be a little difficult to work with and doesn`t always settle out smoothly. You would find it easier to use fumed silica or microballoons as your additive to the resin for filling voids. Then use straight resin and glass cloth to build up your repair.
Posted : June 20, 2005 4:03 pm
(@Barnicle_Bill)
ok, i need all of your guys' expert advice here... i just bought my boat and soon found out that i have a leaky hull, i first used marine tex on the bottom of the hulls (they'd seen better days...) and it still leaked, then i redid the silicone on the gudgeons and drain plug... and it still leaks... where could water possibly be getting in??? and how can i fix it?
Posted : June 21, 2005 10:08 pm
(@Anonymous 38896)
I dont know that much about fixing the bottoms of the hulls, thats why I posted this thread. (although I think i finally figured out everything I need to do, thanks a lot guys) But anyway, as far as other leaks, as has been mentioned in other threads one good way is to cover the hull in soapy water and run air in through the drainplug. I actually took an old drainplug and attatched a valve to it so I can hook it up to an air source. If the hull leaks then you shuoldn't run a danger of putting too much pressure in it, but keep an eye on the pressure anyway just to be safe. The places where the soapy water bubbles are the leaks. Suspected places are the bottoms of the hulls, the drainplug seals, the rudder assembly attatchments, the deck/hull joint, and the points where the 4 posts that support the frame go into the hulls. Supposedly once you get everything sealed right the hull will actually hold a little bit of pressure and you will hear a pressure gradient equalizing everytime you take out the drainplugs after sailing. My hulls have never been that well sealed though, so maybe you should get more advice from some of the mose experienced people here.
Posted : June 22, 2005 8:27 am
(@Anonymous 38734)
I would definitely not use any pressure beyond what a vacuum cleaner can generate. Besides the hulls are vented in the pylons and there should never be any pressure build up. If you pressurize with a vacuum cleaner like a shop vac in blow mode you should have enough volume of air flow to generate a pressure enough to find bubbles in your soap solution. Whatever you do, don't connect any compressed air to that valve you installed in a plug. Assuming a hull is 16' long and averages 1.5' high, a 1 psi pressure would cause a force trying to pull the hull apart of over 26,000 lbs. A vacuum cleaner generates pressure in inches of water, maybe 3 or 4" where 1 psi is equal to over 2' of water column.
Posted : June 22, 2005 10:56 am
(@Barnicle_Bill)
will a hair drier work well?
Posted : June 22, 2005 2:18 pm
(@Anonymous 38896)
thanks for the concern but I already thought about that. I wouldn't want to make even MORE leaks :P. Anywya about your fix, you mean this guy had resin and stuff with him at the beach and put it on immedately? That sounds kinda odd. I'm being carefull with mine, I have the mast off and the boat upside down so I cant sand it properly and everything.
Posted : June 22, 2005 2:38 pm
(@dpcarey)
Fellas,
Careful with pressure. I agree with a vacuum cleaner blower approach. However, it is my understanding the the H16 hull is not a true "air-seal" and pressure is supposed to equalize through the foam plug in the pylons. Therefore, you should not be hearing a swoosh of air when the drain plug is released. Perhaps someone else can chime in on this.
Also, if you can`t find the leaks, look very closely at the sanded ridge where the hull bottoms mate with the hull caps. ie. this is the relatively flat and sharp ridge you get your fingers under when lifting a hull. You will find many defects along this ridge. They resemble little pits and holes. Some of these are air-bubbles formed in construction and are unpreventable for the most part. Water can leak through some of these. I was able to pass fluid out from the hulls through some of them by rolling the hulls (slowly) across the saw-horses I had placed them on during restoration. I found that I was unable to fully discern ALL of pits which leaked from those that did not. As a result, I used a small amount of polyester resin mixed with a small portion of microballoons (to prevent running) and plugged all the pits I could find. It took me about 20 minutes to do this with the hulls positioned upside down. It would be much trickier with the boat assembled but certainly possible. I imagine there are several other approaches and sealing methods to this problem as well.
Posted : June 22, 2005 4:55 pm
(@Anonymous 38734)
To answer the question about a hair dryer, it would not generate enough pressure or volume to do anything. The vents in the pylons would probably flow all the air the hair dryer would produce.
I agree that there should not be any pressure differential noticed when you remove a drain plug. If the hulls weren't vented you could not drain water out of the hulls under normal conditions.
About the repair on the beach that I described in the private message, the fellow who fixed my hull had a business of several Hobies that took people out for rides. He maintained his boats and had all the materials he needed to fix mine.
Howard
Posted : June 22, 2005 5:28 pm
(@Anonymous 38896)
yeah, i've never had my hulls make the air release noise either, that's just what i've heard other people say. In theory yes in order for water to drain out of the plug most efficiently there needs to be air comming in from somewhere else. However if seems like if your hull was so well sealed that pressure was equalizing then it would never take on enough water for this to be an issue and the little bit of water if you ever took any on would still drain out in a fairly short time. With this taken into consideration, do you think it's a bad idea to try to seal above the pylons?
Posted : June 23, 2005 8:28 am
(@dpcarey)
Aaronhoy,
I am a little uncertain regarding this part of your question:
"if your hull was so well sealed that pressure was equalizing then it would never take on enough water for this to be an issue".
But, since I have the time today, I will try and cover all the obvious angles on this.
With regard to a perfectly sealed hull being unable to take on any water, I would have to say you are perfectly correct. However, as ambient temperatures rise and fall and the internal temperature of your hulls change, you can expect significant changes with the internal pressures of the hulls as well. These could be greatly enhanced or inhibited by the effects of cool water or the radiant effects hot sunshine. Those experiencing the aforementioned "swoosh" are subject to this situation. Although I cannot comment on the particular strength of the H16, I can say this could be very bad. It certainly could accelerate a delamination process (especially in a cored layup construction) and possibly even crack open a hull. The concern over a "perfectly sealed" hull then becomes an issue of damage from pressure as opposed to water.
I believe the Hobie techs could address this much better than I can, but it seems pretty straight forward to me. If the architechs and builders of the hull wanted it truly air-tight, they could have done it in the factory with relative ease. The real trick appears to be how does one significantly minimize water accumulation while maintaining good pressure equalization...again, not a tough thing to do. This is even easier than creating an air-tight hull. But, sealing the pylons (vents) would not be a good idea at all - in my opinion. If you are trying to find some special point where the hulls just barely leak air (equalize) yet somehow completely inhibit water intrusion, I would have to say it is not a realistic goal. The best you can hope for is to plug all leak points on the fiberglass hull itself and be sure that the foam plugs in the pylon are in good firm condition so that they cannot simply act as funnels for water to enter the hulls.
Posted : June 23, 2005 9:06 am
(@Anonymous 7292)
I recently found some small air leaks by presurising the hull. All it took were 5 or so large breaths blown into the bung holes. This also allows one to hear the fine pitched sound of air leaking as you build up the pressure. It's probably easier too...
Posted : June 23, 2005 9:44 am
(@dpcarey)
Clint,
Nice low tech approach! Always worth a try! However, I am surprised by some of the difficulties people are experienceing here. The leak points should be relatively easy to find if you know where to look.
As I have been thinking about it, I have a suspicion some of these mystery leaks MAY be occurring below the waterline at the sites of previous repairs. If sailors are not using the proper process or materials in their patch work, then leaks may still occur. This is why I have repeatedly posted that simply slapping on some type of filler, or cloth and resin, may not do the trick (at least not for very long) on anything but the smallest repairs. I also think some might be omitting a proper cleaning process and/or an initial sealer application of thin resin (without fillers). Only after these steps can resin fillers and/or lamination be applied with any confidence.
If one does not follow these steps, it almost guarantees eventual seepage through previous repairs - especially along an edge like the bottom of the Hobie hull.
People who work with fiberglass understand these particular issues well - it goes with the territory. For everyone else, it is a matter of finding (and trusting) good information.
Posted : June 23, 2005 10:11 am
(@Anonymous 38896)
yeah, that's what i'm planning on doing, I was gonna apply a thin coat of resin over the entire damaged area to let it seep in anywhere that might leak water and then start applying sheets of woven fibgerglass. Shouldn't this ensure a good seal?
Posted : June 23, 2005 11:08 am
(@dpcarey)
Aaronhoy,
Yes. Now you`re talking.
Remember to clean first and get rid of loose debris. Don`t be afraid to re-apply the thin coat if you are not confident with the first. Fill voids to even out the surface (within reason) with a filler/resin mix before laying on your weave - otherwise air pockets will form and osmosis and more leakage may occur down the road. Avoid trying to "plaster" with the filler - just do the voids. Try hard to do it all in one day so as not to allow a full cure in the last layer (which ever it may be) before applying the next.
Do this, and you will succeed...especially if you use a quality epoxy.
Good Luck
Posted : June 23, 2005 11:23 am
(@Barnicle_Bill)
i hear much talk of these holes in the pylons to equalize pressure... yet after a pretty thorough inspection of my boat, i have no idea where they are... where in the heck are those things?
Posted : June 23, 2005 12:00 pm
(@Anonymous 38896)
ok, great.
so when people talk about filler can I just mix chopped fiber stands with epoxy or is there a seperate material I can buy that is acutally labeled as filler? Also, all the times i've dealt with epoxy before (in non-marine situations) it has been in 2 parts. However I haven't noticed anyone talk about this in the forum. Will the epoxy I find at west marine be 2 parts or is it different?
(@dpcarey)
Newbie,
Very good question. The pylons themselves are hollow and are similar to your mast or boom. Access to "the hole" and foam plug can only be achieved AFTER removing any of the four corner castings... Then you will see it plain as day.
Aaronhoy,
Epoxy always comes in two parts. However, it is not always mixed in a 50/50 proportion (read the label). Real care should always be taken to mix resins and hardeners as accurate as possible. This is quite easy to do with volumes of more than a few ounces. But, with small amounts it can be tricky. I use a small electronic postal scale which is accurate to a single gram. This solves the problem nicely. For you, it is better to stick with volumes large enough to accurately read using whatever (disposable) measuring device you happen to be using. Always pour the thicker of the two parts first as it is much easier to pour the thinner of the two parts last for an accurate measure.
As for the filler - chopped glass, microballoons, fumed silica...even baby powder in a pinch etc. These are purchased separately and usually fairly inexpensive as well. The resin supplier should have these on hand. Ask for them by their individual name as opposed to just asking for "filler".
I wouldn`t recommend chopping up fiberglass into small fine strands. Otherwise you`ll be scratching your butt off for days, and 20 years from now you`ll be writing all your posts from your hospital bed - provided you can reach your keyboard past your ventilator hose!
Posted : June 23, 2005 1:44 pm
(@Anonymous 7292)
Low tech is the way Before going for the labour intensive methods..I was just lucky that I had three minor leaks in easy areas to work on. I'm sure my day will come when I have to check up your posts Dave for a big job.
Posted : June 24, 2005 2:55 am
(@Anonymous 38896)
ok so today I started on the fiberglass. On the first layer of one of the hulls the resin cured before I was done and there are some placed where it is sticking out on the edge and a few air pockets, so I decided to quit with that one for the day and let it cure and then sand it back into shape before I apply more glass. The other hull went well though. I guess it is important to do small strips at a time because if the resin gets tacky in the middle of doing a strip it will never stay down after that. Any suggestions as to how to remove the unstuck material?
Posted : June 26, 2005 11:02 am
Jim
 Jim
(@jaimezx)
Quote
Dremel and heavy-duty cutting wheels and patience. (Be sure to get heavy duty because the regular ones break too often. I dunno why they even sell regular ones; they're worthless.)
Posted : June 26, 2005 1:07 pm
(@Anonymous 38896)
oh yeah, I used a dremmel to cut metal for the frame of a small robot once and I went through like 10 disks. One time a shard of disk nailed me square in the safety glasses. Anyway I went back down there after the supposed 2 hours cure time and it was still tacky in some places. I decided to try to sand it anyway to see what happened (with a power sander) and it sanded ok and then the stuff was hardened by the time I was half way done. I took off the hanging edges and power sanded through the air bubbles and then hand sanded them long ways to make it smooth. Hopefully I will be able to finish the rest all in one day sometime this week now that i've got the hang of working with this stuff.
thanks all for your help
Posted : June 26, 2005 6:29 pm
(@dpcarey)
Aaronhoy,
For removal of cured glass, I find 80 grit paper and an orbital sander works best. Wait until the resin is fully cured though (at least overnight).
Also, I think you may be confusing "fully cured". Resins fully cure (for general purposes) in about 12 to 24 hours. They become tacky in about an hour or less (depending on what you`re using). It is quite alright (in fact desirable) to let the last layer get tacky before applying the next. This is not the same as fully cured. Also, do not use resin that is starting to gell in the mixing cup - mix fresh stuff.
Posted : June 27, 2005 3:11 pm
(@Anonymous 38896)
yeah that's what i was trying to do was let it get tacky and then apply the next, but some of it got tacky while i was in the middle of a strip, making like an edge of it that kinda had resin on it but wasn't soaked all the way and wasn't stuck down against the side when it got too tacky to manipulate. I knew it wasn't fully cured when I came back to sand it (even though the directions claimed it should be) because I could feel that it was still sticky, but it was still hard enough to sand so I went ahead and got rid of some the bubbles and that sticking up edge. I used a sanding disk on an electric drill, which is just as good as an orbital sander.
Posted : June 27, 2005 3:35 pm
