main sheet dropping overboard through trampoline
We are going to participate the [color:
red
] Round of Texel <img src=
/>- The Netherlands- June 23, 2007 <img src=
/> (biggest Catrace in the World [ http://www.roundtexel.com/ ] with almost 500 subscriptions already!!) In rough conditions (waves) the main sheet tends to slip through the apertures in the trampoline <img src=
/> - especially the rear one. Very inconvenient when both hanging in the trapeze! <img src=
/> Tried to avoid this by inserting kind of mesh which actually does the trick more or less. Does not seem to be a long lasting solution however. Anybody a (better) solution?
other question: we have to have 2 paddles somewhere on board - which we will almost for sure never use. We would like to attach them under the trampoline to keep as much free space as possible. Any suggestions?
I put the paddles under the tramp in the middle, parallel to the hulls. Used some old stretch cord to create loops, which I tied around the tramp lacing running up the middle. I put the paddle in from the back, handle first, then stretch the front cord to wrap around the small handle (if you don’t have you can improvise). This works really well, never in the way, tight up, so no dragging and easy to get when needed (might have to get a bit wet).
I use a plastic paddle that flexes a little and I put it on top of the tramp. The handle goes up through the lacing a few inches, then I slide it back to get the end of the paddle blade under the lacing. It isn't in the way yet easily available. It helps keep the main sheet from going through the lacing but doesn't eliminate it from happening.
Howard
- 3,376 Online
