Major rudder problem!!!
WEll..i was bringing my rudders int my basement to get ready to fix the alignment problem and fix the stuck cam. Then the rudder swung out when i was holding it, it hit the floor and the the part of the rudder around the bolt that attaches to the frame(not the part that locks down) BROKE and the rudder fell off. Has this ever happened to anyone, or is it just because the rudders are like 30 years old?
The rudder itself broke, Correction:, it did break around the bolt for the arm that locks down, not for the frame like i said before. So just imagine that where the bolt for the arm attaches to the rudder, broke off so that the bolt cant hold anymore. Pretty much a chunk of the rudder broke off....ughh Im guessing im just gonna have to buy a new rudder right? there 100$..not to bad. how much is a whole rudder assembly with everything?
Depending on how and where it broke, I would be tempted to drill through one piece into the other and epoxy in some kind of long slender screw or two or three.
Of course if it rebreaks you might end up having a great afternoon of sailing terminated by a crawling back to the marina.
been there done that.....use epoxy---I like the west system....i used x-ray film to wrap around the rudder, taped it down, poured epoxy/harder/hidensity filler--(consistancy of peanut butter)...let it dry. then i sanded to make the rudder back to the original shape. drilled the hole, and went sailing......no problemo....t
- 1,193 Online
