Making a h14 dolphin striker
Is 1/4
Stainless Steel rod OK for the stringer? (For trappezing, not for using a jib.)
How does the vertical post nest on the front crossbar base? Is it attached as in rivets.
I am planning on welding a piece of SS to the base of the 5/8
SS vertical post to spread the pressure over a wider area. The base will be bent somewhat to follow the curvature of the Crossbar. I will probably put some epoxy on the mating surfaces to reduce the likelihood of galvanic corrosion.
Also what is the standard post length from the crossbar to the rod (stringer)?
Posted : July 8, 2006 7:58 pm
Forum Information
- 1,571 Online
Our newest member: TooTallTom
Latest Post: Hobie pearl / tiger mast needed
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
