Mast over-rotation question?
I have an older H16 and the stops on both the mast base and step are worn in a way that allows the mast to over-rotate by about 10 degrees.
Can someone tell me how significant this is? Will it change the boats performance? If so, in what way? Anybody have a fix for this besides replacement?
Posted : October 18, 2005 10:02 am
Over rotation will flatten the sails upwind. This can be good in higher wind, but less power is a performance loss most times.
You can cut away a little more of the stop, drill, tap and insert a stainless bolt. Cut it flush and grind flat as a stop. Cheater than replacements, but a lot more work.
The new steps and bases work really well and wear less. well worth the cost.
Posted : October 18, 2005 2:34 pm
Forum Information
- 3,362 Online
Our newest member: TooTallTom
Latest Post: Hobie pearl / tiger mast needed
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
