proper use of jib sheets
1 Users
(@_removed-account)
Four Star Admiral Registered
[#8824]
apart from having the issues of getting the jib battens to get past the mast on both tacks and jibes, i am wondering which sheet i should be using when trimming the jib. currently, i am letting both out and using the windward sheet to bring the jib in but it develops too much of a curl at the bottom, so i end up pulling on the leeward jib sheet to straighten the bottom out.
is this the correct method?
thanks in advance,
jeff
success is not having to work in may and october
- art garfunkle
Posted : July 29, 2001 10:52 pm
(@_removed-account)
I recommend first setting the jib traveler cars at the right position for your point of sail. (more inboard for close-hauled and more outboard for broad-reaching). Then use the leeward sheet to tighten. I think you will find that this will help get rid of most of your hooking problems.
kyle <
h16 80065
Posted : July 30, 2001 8:28 am
