Restoration questions
6 Users
(@swanbike57)
[#19883]
I am restoring a 1982 H16. Couple of Questions:
1. When I flip the hulls over, the flotation foam clunks around. Should I secure the flotation with Great Stuff or not worry about it? I have already cut holes for inspection ports in the decks.
2. What product is recommended for the side rails- tape or carpet? I am a newbie so I will be daysailing not racing just yet.
Posted : May 1, 2007 10:44 am
hobie1616
(@hobie1616)
1. If the foam is in good condition I wouldn't worry about it.
2. I like carpet. You'll get a lot of opinions yes/no on both.
Posted : May 1, 2007 6:43 pm
(@dbncsu)
The tape that came on my rails didn't hold up very well. I would use carpet.
Posted : May 1, 2007 10:14 pm
(@banzilla)
I heard/read somebody was fairly happy with a spray on bed liner for trucks. I might give that a try this season.
Posted : May 9, 2007 9:53 am
 Karl
(@sogncab)
I posted somewhere wondering if anyone had tried using the bed liner stufff. Don't know how well it would work. Someone had mentioned the weight being a factor too. You first <img src=
Posted : May 9, 2007 4:25 pm
(@banzilla)
I am wondering how much heaver it could be than wet carpet. After all, it is just a strip about 4" wide and the length of the side rail. Now if you were going to do the hulls also that might be a concern.
Posted : May 11, 2007 10:22 am
(@ucosailor)
I would be hesitant in using either tape or spray-on material due to the abrasiveness of the surface. I have a tendency to slide in from trapping or hiking out and have lost skin from sandpaper like substances. My personal preference is for a softer substance that still maintains traction when wet. For side rails I prefer carpet due to the bungee on the trap wire, while on Hobie 20 style decks I prefer hydro turf.
Posted : May 11, 2007 1:28 pm
