Rudder cavitation or stalling
2 Users
(@Anonymous 16536)
[#13623]
Hi all,
Don't know if it happens to other people but, sometimes, going upwind, two-trapped, the rudder seems to go crazy, the boat gets slooow and we end finally into irons.
Any tips on how to avoid it, or at least how to recover from
it?
aestela
H16 157597
Posted : April 26, 2004 9:01 am
deq204
(@deq204)
First off is how to prevent it – To prevent this – you need to rake your rudders under the boat as much as possible. Based on your sail #, you have a newer boat with adjustable rudder cams (a hex bolt on top of the rudder casting).
Second – To relieve the pressure while sailing – Get back and sheet out – Get back on the boat to sink the rudders
and
Sheet out (a little at a time until the pressure on the rudders is relieved).
Hope this helps
DEQ204
WWW.Fleet204.com
Hobie 16 North American Championships
Posted : April 26, 2004 11:21 am
(@Anonymous 1624)
Aestela,
If by "going crazy" you mean the rudders jerk back and forth, then you may have them raked too far forward. You may actually need to rake them backwards. Too much forward rake actually makes the rudder more sensitive and this may be your problem. You need to clarify what you meant by going crazy.
Posted : April 26, 2004 11:33 am
(@Anonymous 16536)
By going crazy I mean mainly noisy and turbulent flow. The perceived steering lose may be produced by the boat going very slow or stopping.
Posted : April 29, 2004 1:43 am
