Saying hi and a little question
Hi all,
just found this brilliant page. I am a (recent) proud owner of a 1991 Hobie 16. I am sailing in Cadiz bay, South Spain. I would like to ask the pros here, what would you recommend as a "strong" cleaning agent? I have had some oxid/water dropping down from the shrouds, and now I have a red vertical mark on the hull. I have tried with different "smooth" cleaners (soap etc) but I could not get rid of the mark. How about using solvents? What kind of solvents would you recommend? Or might this affect the hulls? Any hints are very appreciated.
Regards, Claus
Oxalic acid will take most stains out of the gelcoat.
In the US, there are a number of products that contain it as their active ingredient:
Davis Products Fiberglass Stain Remover![[Linked Image]](http://www.bestboatcare.com/FSR%20Hull%20Cleaner.gif)
is probably the best.
There's also
And
But I don't know if any of this stuff is available in Spain.
Hi Rony,
I used Sadira (the name of the company) "Limpiacascos" for the hulls (which was suffcient to get rid of the rust), and Sadira "polvo limpiador fiberglass" for the deck. The last one contains the named acid and leaves the deck very clean. I think it is wise to wax/polish the surface after a treatment with such a strong cleaner, though. Does Currito need a thorough clean up too?
Saludos, Claus
OK. Pues sí, yo creo que no le vendría mal un blanqueado porque los cascos están un pelín amarillentos. Ya te contaré.
OK. I think a whitewash will be good for my catamaran because hulls are a little yellowish. I´ll tell you the result of it.
Saludos.
RONY
http:/
- 1,930 Online
If you've got sensitive skin, then use rubber gloves, too.
