self releasing trapeze shock cord ?
Did some searching within the forum but with no luck.
When capsizing / front dive (not to often anymore but still happening when sailing on the limits) we/I often destroy the shock cord holding the trapeze in place when not in use. <img src="<>/mad.gif" alt="mad" title="mad" height="15" width="15" />
Made separate cords for all 4 to avoid loosing 2 at the same time but I'm looking for a better solution. <img src="<>/confused.gif" alt="confused" title="confused" height="15" width="15" />
I'm interested in a hook or similar device that gives way / opens at
extreem
force. After righting the cat just re-attaching the trapeze and continue sailing. Just haven't found right part.
Anybody suggestions?
Some people have added a couple of blocks, on each side, under the tramp, in effect, doubling the length of the shock cord. This may extend the life of the cord, when overstretched, from trips around the forestay or off the back of the boat. I'd bet over time the results will be the same, and then you're replacing twice as much cord.
I have the plastic ends, but don't see them as practical for use as a quick release. There will be too much tension on the cord. Even using the hook without a keeper it would take two hands to release, IMO
I use the small plastic hooks (the kind that attach with a ferule) for 1/4" shockcord. They'll break before the cord blows, and they only cost like $1 (US). When you crash and break one, you can get by with a couple of half-hitches until you get a chance to replace.
I do this on my CAPRICORN... It works a treat. I've been on a few missions out past the spinnaker and haven't snapped them.
Give that a go <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
- 3,126 Online
