Solo mast raising
Did a quick search and could not find anything on solo mast stepping. It's getting to the mid 40's here and that makes it harder to convince my crew to come sailing. What is the best method of single handedly raising the mast? Gin pole on the mast base, pole on the trailer tongue? Just looking for some experienced views here. Thanks
Mike,
I presume you are talking about an H-16. I raise my mast alone all the time. I use a tripod to hold up the end of the mast. I tie a line about 8' long from the jib halyard to the bridle. Making sure that the shrouds and wires are clear and won't catch on the tramp supports, I raise the mast. I then lean into it, reach down and uncleat the jib halyard, pull the halyard tight, and cleat it off to hold the mast up. I then get down and put the pin in the forestay. Dropping the mast is just the reverse.
Howard
I typically fly solo, so have done this a few times...
I use one of those folding step ladders as a rest for the mast while stepping it (definitely helps in getting the mast started up). I untie one of the jibsheets from the traveller, and tie it off to the forestay. Once the mast is raised, I just cleat in the jibsheet, and it holds the mast in place, while I go up front and pin it in. Raise the jib, releasing the tension on the halyard, and untie the jibsheet. Then retie the jibsheet to the traveller, and off you go...(after raising the sails, of course)
This way, it doesnt need any additional lines, poles, wires or such.
Monte,
Do you take the jib sheet around the bridle and then tie it to the forestay? I can't quite picture otherwise, how the jib sheet would hold the forestay to hold the mast up.
One advantage of using the jib halyard and a piece of line, is that when the mast is up and the halyard cleated, the forestay is loose and easy to handle. It usually is very easy then to pin to the adjuster especially with the bridle held up in place.
Your folding ladder sounds like a good idea. I use 3 aluminum tent poles that I drilled and tied with line to make a tripod.
Howard
Yes, I take the sheet around the bridle. IT can be a tight squeeze in the adjuster my way, with the jibsheet attached to the forestay, and trying to pin it. I will have to try it your way, sounds like it might be easier to pin the forestay, and it only takes the extra length of line.
I am not sure but I believe the comptip mast is heavier than the all aluminum mast. My mast is all aluminum. Also check to be sure there isn't any water in the mast.
I find that it seems heavier in the beginning of the season and gets easier. I am 73, had heart surgery in March, and was raising the mast solo in June so it isn't that hard.
Howard
- 2,400 Online
