trailing a Hobie
(@Anonymous 37835)
[#11797]
I was wondering were the supports on the trailer should be. The hobie sits on the trailer right in line with the front and rear pylons. That leaves the whole front of the hulls sticking out there. Were as my friends sits about 2 feet in front of the front pylons. Is it ok to have the hulls sitting out that far or should I rework the trailer and move the support forward?
Posted : April 19, 2003 9:28 am
(@h16bill)
When Hobie 16's are laid up the keel area is all solid glass so there is
no real worry about where it sits on the trailer.
cheers
Bill
Posted : April 19, 2003 7:57 pm
(@Anonymous 37782)
It concerns me the way my boat loads with the center of gravity so far forward, but I have towed my boat for thousands of miles this way without any problems. Just be sure the rear of the boat is securely tied down. If the rear is not tied down, the boat will want to tip over forward.
David
Posted : April 21, 2003 6:54 am
(@Anonymous 37835)
I was hoping to get a few more opinions. However since no one has disagreed with h16bill or HobieDave I guess I'll leave the trailer as is.
Thanks guys on your thoughts on this subject.
Posted : April 24, 2003 5:14 pm
Jack Hoying
(@Jmhoying)
Hi,
When I switched from a Hobie 16 to my Prindle 18 (same trailer), I thought it looked like a lot of weight on the single front roller. I thought about picking up some fiberglass hull cradles, but instead went with a double roller system. This spreads the weight out quite a bit. I have some photos of it at http://www.thebeachcats.com . Just go there and do a search for "double rollers".
Good luck,
Jack Hoying
Prindle 18
Fort Loramie, Ohio
Posted : April 24, 2003 5:30 pm
(@jkartz)
We used to trailers 2 16's on one trailer. Other than the wind drag that caused the gas milage to plummet when driving over 55, we never had any problems.
Posted : April 25, 2003 7:47 am
(@twopaddel)
Watch how you weight the thing too wuch weight on the toung and it might get squirly vise versa. I found this out towing my boat from San Diego to New Jersey
Posted : April 30, 2003 8:21 pm
