Trapeze lines
It would work. I have mine like that. Wish I had two instead. I use one line 90 or more percent of the time. But I have to mess with all four lines every time I set up. Wish I could just add the one if I would need it. Separate them so you have one less thing to hassle with.
Nova,
Why do you say you have to "mess with" the trapeze lines every time you set up? I leave trapeze wires and shrouds connected at all times. When I put down the mast I coil up the slack and tie them on the tramp. Setting up I use a tripod to set the mast on and uncoil the shrouds and trapeze wires. I raise the mast alone so I have to be careful the wires don't get caught on the tramp frame. I temporarily tie the trapeze wire bungee cords up near the dolphin striker to keep them in position. I've been doing it that way for 20 years.
Howard
the trap wire set up will work like that ... IIRC you can buy them like that from Murray...
Boat set up... I have to remove all shrouds and wires and forestay in order to store the mast in my garage. If the mast remains on the trailer and you are not concerned about people stealing you stuff - sure keep it attached to boat and mast. It will safe you some time setting the boat up.
Patrick
- 885 Online
