Tuning a Hobie 16 for a race
Hi Kappie
Where are you racing? I'm new to racing myself and found the best way to learn about tuning is from other sailors. You'll find most Hobie sailors are pretty relaxed in sharing knowledge. So for some good advise, ask one of the sailors rigging next to you if he could point out a couple of things on your boat he might improve on
some things i do
check the toe in of the rudders- about 3/16"
check the mast rake. should be nearly block to block with maximum mainsheet tension.
tighten the tramp.
check and/or replace tell tales and wind vane
clean the hulls and rudders.
spray lube the mast step, all the blocks, the rudder cams,and the traveller track.
read the race instructions. again.
arrive early. set up and sail early. attend the skippers meeting. then
sail fast and have fun!
- 2,409 Online
