Heating your workspace, ideas?
For our Blade F16 project we need some ideas. We are working in my garage, and there is just the usual
holes in the wall
and under the garage port for ventilation. Last winter we used some 200W bulbs directly over the hull panels to heat them while the epoxy set. It worked, but I was not impressed with it. The garage is not insulated very well, so we need some KWs from our heatsource.
A fellow builder here in Norway use a paraffine/diesel heater for his workspace. I have been thinking about a natural gas heater. Using electricity is not very economic anymore..
What do people use, and what kind of precautions do we need to take with the different options? Risk of fire is something I denfiately want to minimize!
Rolf,
first I would think about proper thermal insulation. No point in heating the back yard too. Second I would use water as a transport medium. Natural gas burners are very good, if you have a gas pipe near you. A gas burning powerplant can provide all the hot water and heating you need for your home. The unit is very small - aprox. 45x60x90 cm, you will need to use radiators in all the rooms. But ... is there a natural gas network there ?
I can buy natural gas on 6 and 12liter tanks, but no natural gas network (we export 99.9% of it). I would have to install a chimney/exhaust and run some plumbing and that sounds like an extreme undertaking for one or two winters, at most three winters.
Insulation will happen as best we can.
So what do you use in your workshop by the water Gato? Or dont you use it during winter (it is a lovely workshop, so that would be a pity).
I have been using a diesel heater in my work space. And I have an unheated room for cutting wood and anything else that
makes dust. I will be using the same heater to heat an oven that is built around the mold to bring the temp. up to 55C.
Also I have a small electric heated in a foam box to keep the epoxy resin at about 20C.
A note about my weather conditions, it very rarely goes below, -5C where I live.
My workshop close from the water is not used for wood or epoxy work when the outside temp drops below 15 deg C. Just to heat when working is causing a lot of problems with humidity.
When working wood or epoxy you need a more or less constant temp and humidity to avoid problems. As you can see on my blog, I was working in the living room <img src=
/> when doing the DS12.
I also have possibilities to use the workshop at my work.
Increasing the temperature in the workshop while gluing and especially when glassing is a big no-no. Outgassing is not pretty either <img src=
I think we can have pretty stable temperature when gluing/glassing as long as the heater runs. This workshop is our only alternative unfortunately.
G'day Rolf it doesnt get as cold here as you get but we get down to zero overnight at times. I've found that this setup of 4 x 500w halogen lights gives me good working light and lifts the local working space temperature at a controlable rate by putting the lights closer if need be. I took this photo today and it got down to minus 5 last night outside but you can feel the whole shed is warmer. The downside apart from power cost is that when you turn these lights off after a few days continuous use, most of the globes melt.
regards
That was what we used last winter. Apart from needing cleaning and not directly heating parts in the shade it worked quite well. This winter we want to heat the whole room, as we are working on both sides of the room (1 car garage). We also noticed how the lightbulbs did not last very long, did not think about them melting.
I am becoming paranoid with regards to the power company, so I would prefer to not use electricity for heating. 2000W is pretty expensive considering how we will be working most of the winter. Thanks for the tip anyway!
What boat is that in the picture?
Hi Rolf,
My shop is a detached building and has insulated walls and roof. I use an electric baseboard unit of about 2.5 KW. These are cheap, easy to install, and about as safe as you can get. On the coldest nights it will keep the shop at 50 DegF (0 - 10 outside). To supplement this I also have a propane unit that screws directly into the top of a 20 lb. propane tank.
One thing to keep in mind is that a 5 gallon bucket or 55 gallon drum of resin takes forever to reach ambient temperature when you turn on the heat in a cold shop. I used to try saving money by keeping the shop cold until it was time to do a layup but this turned out to be not very practical. Then, I tried hiding containers of resin in odd corners of the house and my wife got really pissed at me.
Kevin
Thanks Kevin.
I have a heat box for resin, a simple 60W bulb in a box with the resin. This keeps the temperature of the resin surprisingly stable.
The propane unit you use, is there any open flame there? I would not be comfortable with open flame in my workshop, and a thermostat would be nice. Preferably not running on electricity for its main energy consumption <img src=
I know I am asking for something which might not be out there.. Sorry.
Hmm, this may take a bit more looking. I was thinking that the Coleman camping products may work but they include this warning in their documentation:
During operation, this product can be a source of
ignition.Never use the catalytic heater in spaces that
contain or may contain volatile or airborne combustibles,
or products such as gasoline, solvents, paint thinner,
dust particles or unknown chemicals
I was wondering if the Coleman type products were the same as the the other catalytic products that keep the process below auto-ignition temperatures.
I checked for a Norway rep for the product I linked earlier. It turns out, he is in Canada.
CCI Thermal Technologies Inc.
2721 Plymouth Drive
Oakville, ON L6H 5R5
Contact: K.B. Ting, Vice President - International Sales
Phone: 905.829.4422
Fax: 905.829.4430
Toll Free: 1.800.410.3131
E-mail: kbting@ccithermal.com
Last night was fun. We winterized the workshop. 0 to 3 deg C last night, and this morning it was still 10degC in the workshop. That was pretty good concidering that we did not have a heatsource active in the garage. Looks like something out of NASA, dont it <img src="<>/wink.gif" alt="wink" title="wink" height="15" width="15" />
In reality it is just some cardboard and aluminium foil, rubber gaskets on the port to the workshop etc. So far it seems to work well, and lighting was also improved. At least we think so. But what do a couple of tin-heads know <img src="<>/laugh.gif" alt="laugh" title="laugh" height="15" width="15" />
The heaters designed for workshops that use the waste oil from your local car or truck garage are the biz, steady heat and relatively free from fumes smells etc, downside they are a high initial cost but if you can source the oil for nothing then payback is quick.
I've had far too many diesel space heaters that you end up smelling and exhaling breath that smells of oil fumes, doesn't half kill the old passion sessions with the better half, straight off.
The LPG Green House heaters which are thermostatically controlled, if your workshop is large, are really good, downside is they do end up putting large amounts of condensation into your workshop which is not great for epoxy.
The best workshop heater I've had was a wood burner, get a good quality one and you can shut them down enough that they will still light the next day, you don't need a very big unit either as they are better to be run at mid heat than to control them down to far where they fume and
oil
up the flues from lack of heat. <img src="<>/cool.gif" alt="cool" title="cool" height="15" width="15" />
We went for an electric heater instead. One similar to this one:
It have relatively low surface temperature, a good fan, overheating protection (cuts power), easy to inspect and can be cleaned with pressurized air. We got it just this weekend and it seems to do the trick. Was very cheap as well. Just GBP20.
We also found a cheap
industrial
vacum cleaner, so now we can clean up the mess from the sanding before we turn on the heat and work with epoxy.
I need a larger workshop though! Hope to be able to build a boathouse/workshop just by the sea in some years.
In winter one kwh is about NOK1,- or GBP0.093
Not cheap, which is why will run the heater before we glass/glue for 12 hours (thermostat of course), and then turn down the thermostat somewhat. No heating between epoxy sessions, which means the temperature will drop down to about 10degs with our current insulation.
In winter even with my worklights the resin was really slow to go off so I purchased a gas patio heater and made a smaller enclosure in the shed out of poly tarp. I did the Nacra keels this week in direct sunlight and it went off too quick. Is it practical to heat from the inside of the hulls to say 18 degrees and then epoxy with the lights giving some lift in external temp or is this risking the integredy of the hulls.
regards
If you are glassing, be careful with outgassing from the wood (if you are building in wood). Outgassing results in a lot of tiny bubbles in the laminate.
We wanted a fan to circulate the air so we get an even temperature at all heights in the workshop. We thought about IR heaters, patio heaters etc, but in the end the workspace heater was our best solution. Tested it over the weekend and it looks like our insulation work combined with this even is the thing.
Looks like you have something similar in your workshop. The little yellow thing at the front of the hulls looks like an electric fan heater. IP44 standard?
If you heated the interior of the hull to 20 degrees then got the area around it to a similar temp with the heat lights would that prevent outgassing.
The little yellow thing is the patio gas heater with a built in electric blower so that it blows the heat around the workshop. I had to ventilate the workshop after using the resin then turned it on. Sort of the Darwin theory you know you've ventilated enough if you dont blow up.
One thing that is surprising me a bit is the fact that you don’t seems to worry about the humidity.
To obtain a good result the wood should be kept as dry as possible and that will not be the case if storing it in a place that is not permanently heated. It’s no use to seal wet wood with epoxy.
In my case the humidity in the workshop is around 35%. At least it was the last time I checked. I have a hygrometer in the workshop together with the thermometer. The wood dries quickly when cut into planks/strips.
I dont think the humidity really changes a lot with cyclic heating, but you increase the capability of the air to hold humidity when you raise the temperature. Unless you bring humidity into the shop and the workshop is dry, I dont think it is a problem.
I dont let any moisture form in the shed and I ensure everythings perfectly dry before I work on it by preheating the shed for a few days before and keeping the heat going. I was just trying to tap Rolfs experience to see if there was a way to reduce the heating bill.
Ready you serial lurker its good you've come out of the closet, I am carefull I always cringe and close my eyes when I turn the heater on.
regards
- 6,313 Online
