1182 ......'Twice Shy'
here we go again.... <img src="<>/crazy.gif" alt="crazy" title="crazy" height="15" width="15" />
So how did I end up with this old girl .....
Well like most of you, I had it on my eBay watch list, and I had no intentions of actually bidding to buy, A closer look of the pics and a message to the owner said it was mostly good but in need of some TLC, a few missing parts which turned out to be the screws for the tramp and the rudder pins.....
Everything else is there <img src="<>/grin.gif" alt="grin" title="grin" height="15" width="15" />
So its a late lunch and my phone does the buzz for an ebay item that's about to finish, have a look and its not moved in price since earlier in the morning...... oh what the hell, I'll chuck a couple of hundred at it and that should stir things up for the real bidders.....
submit bid..... congratulations your the highest bidder <img src="<>/cool.gif" alt="cool" title="cool" height="15" width="15" />
yeah whatever..... back to lunch....
A few seconds later the phone does the buzz thing again, congratulations you've won the item..... huh <img src="<>/confused.gif" alt="confused" title="confused" height="15" width="15" />
So in all honesty I never had any real intentions of becoming a duel mosquito owner but as fate would have it, I now am
<img src="<>/laugh.gif" alt="laugh" title="laugh" height="15" width="15" />
but is that a good thing or not ????
pics from the add
doesn't look too good does it <img src="<>/cry.gif" alt="cry" title="cry" height="15" width="15" />
Oh well .......... SPARES FOR KARP <img src="<>/grin.gif" alt="grin" title="grin" height="15" width="15" />
or is it ???
<img src="<>/wink.gif" alt="wink" title="wink" height="15" width="15" />
Now its home and I've walked around it 20 odd times, its time to see just how bad things really are.....
20mins later and one hull has come up like new !!! <img src="<>/laugh.gif" alt="laugh" title="laugh" height="15" width="15" />
this was just a simple case of a light cut & polish, all up the hulls took about an hour an a bit to have gleaming in the late afternoon sun
things are looking up
<img src="<>/blush.gif" alt="blush" title="blush" height="15" width="15" />
with the hulls basically gleaming in green <img src="<>/sick.gif" alt="sick" title="sick" height="15" width="15" />
it was time to have a look at the mast, first job was to hose off all the bird shyte, then a gentle wipe-down with a scouring pad, then came the 800grit wet&dry paper followed by the alloy polish, all up ~2.5hours spent on cleaning up the mast
<img src="<>/smirk.gif" alt="smirk" title="smirk" height="15" width="15" />
the boom is still work in progress
but its calf-shyte yellowish paint is only the top layer, a cool white lays under that followed by the dark green which matches the strip down the sides of the hull, then comes the alloy...
I hit the boom with 80grit paper on the belt sander and an hour later we had bare alloy again, I then hand blocked it back with 120grit then 180grit and finally with some 320 wet&dry paper, polishing is yet to come but so far its lookin good
(finished pic to come) <img src="<>/wink.gif" alt="wink" title="wink" height="15" width="15" />
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/010_zps0cf04c3d.jpg)
Only other work required on the boom is to replace the shocky cord which has perished in a couple of spots but otherwise its done
<img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
so while I'm sanding/polishing bits I notice a tad bit of movement in the hulls, a quick investigation soon finds the culprit, well actually lack there of <img src="<>/eek.gif" alt="eek" title="eek" height="15" width="15" />
spot what's missing ????
So 2 hours later and several scratches from jagged fibreglass shards, I'd replaced all the alloy blocks with 40mm wide X10mm thick and 60mmlong blocks of high-tensile alloy
these are what's left
NB: pic is as they were removed from the hulls as if you were at the stern .... so the top left is the front left and the bottom right is the rear right block.....
The 'larger' block 3rd in the top row is the one for the missing altogether mounting point in the pic in the above post
couple of close-ups....
well that sucked.... but as per usual there's always an explanation ------> SILICONE <img src="<>/mad.gif" alt="mad" title="mad" height="15" width="15" />
Some of you are probably well aware of the properties of silicone, it has ACID in it and the acid attacks alloy like crazy, someone in their infinite wisdom has used a non-neutral cure silicone and hence we have the ugly corrosion.
Don't belive me ????? duck down to the local panel-beaters and ask for a quote for a leaking windscreen, after you have that rough estimate tell them you siliconed it up a year ago, the quote WILL double instantly, silicone is BAD news if you don't use the right one for the specific application.....
I hear crickets......
everyone must have gone to the shed to see what type of silicone they used to seal that stainless fitting to the alloy mast...
I hope your not too late, relax, the stainless fitting will be fine, the rest tho.....
<img src="<>/shocked.gif" alt="shocked" title="shocked" height="15" width="15" />
What about KARP you ask......
Well I'm still working away on the hull finish, but being so damn fussy meant I wasn't about to get on the water before January or Febuary at best, so as its turned out I should have 1182 ready in a week or so all going to plan on what I've found thus far, and yes there's still one or two more uglies to fix but more on those as I get to them.
1182 also offers me a cheap platform to try things out, the TredGrip I spoke about in the
non-skid: gunwale
thread
http:/
will be one of the first things I trial, if it works to the level I want then it will make KARP's gunwales, I have a few other things to tryout so with this boat I get the chance to play without burning the
good boat
so to speak
As to 1182's future ???
A new name was the first thing, Mistral is GONE so please welcome
TWICE SHY
to the fold <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
mozzie related and combined with the old saying....
Once bitten TWICE SHY and then theres the 2nd mozzie thing.
The name just fitted so well <img src="<>/wink.gif" alt="wink" title="wink" height="15" width="15" />
Its future.....
[yoda voice on]
darkness I see but with a light afar
[yoda voice off]
For now Twice Shy will be patched up and put on the water ASAP, once I have KARP finished then I'll most likely re-deck Twice Shy and take it from there.
There's always someone that wants a mozzie and whether its my sons or she finds a new home or becomes the first mozzie to foil.... couldn't resist that one <img src="<>/wink.gif" alt="wink" title="wink" height="15" width="15" />
At this stage she's moved away from the rubbish heap and I'm sure both I and my kids will enjoy her to the max, and undoutably someone one day will want her for their own aswell
watch this space..... more to come
Kingy
edit:
23 views already...... <img src="<>/shocked.gif" alt="shocked" title="shocked" height="15" width="15" />
get to bed ya silly buggers
<img src="<>/cry.gif" alt="cry" title="cry" height="15" width="15" /> now you tell me <img src="<>/crazy.gif" alt="crazy" title="crazy" height="15" width="15" />
oh well, it gleams good enough for now....
just the shock-cord to fit now.....
Jurassic Karp's boards (colored grey) against Twice Shy's boards (timber) which are 200mm (~8inches) longer .....
and yet the widths are within a millimetre of each other in the board-case area
I'm thinking of cutting off ~150mm (6inches) off of Twice Shy's boards....
thoughts ???
I found a soft spot in the bottom of one hull when I was cleaning / polishing, the paint , it was soft enough to crack the actual paint with very light pressure....
so after I attacked the trailer and started a few changes & repairs, we slipped Twice Shy over and had a serious dig in the region, one soft spot.... turns out I have a few more
<img src="<>/frown.gif" alt="frown" title="frown" height="15" width="15" />
better check the other hull..... and much the same story there too <img src="<>/mad.gif" alt="mad" title="mad" height="15" width="15" />
mutter mutter mutter
The soft spots in each hull line up with each other rather well don't they, obviously water and sitting on the trailer for a few months will do this
so tomorrow's job after I do a tad more with the trailer is to repair these little buggars, I'll square up the holes a bit better and scarf the ends/sides, cut a piece of fresh ply and cut/scarf it to fit and resin it in, I'll add some filler as required and hopefully a lick of primer during the week.
the ugly trailer.....
yeah it needs a tidy up and a couple of minor repairs and mods
the thing I cant get over is just how well this thing tows, bloody great trailer to tow that's for sure !!!
me thinks these have had their day...... well and truly !!!
and with the carpet off..... someone has done some very TLC work here....
high time they were replaced....
the new ones.....
In the above pic (first in the last post) you can see I'd already done the front ones.
finished the 2 rear ones last night (sorry about the pic's darkness but it was a late night
sewer pipe cut/heated and moulded to the hull shape....
Riveted onto a steel rhs base and with 3mm plate added as support wings.
The front ones are solidly mounted whilst the rears 'hinge' down ~25degrees.
just got to glue on the carpet now.....
I'll add a front rack to pickup the front beam and a hinging rear rack to hold the rear beam.....
these slippers will only be used for loading and unloading the boat.
while resin is going off, I decided the orange/red/blue thingy at the bow had to go..... probably very cool back in the day but now ???
definately not my cuppa rum <img src="<>/wink.gif" alt="wink" title="wink" height="15" width="15" />
80grit took care of it and I was able to stay out of the base primer underneath it all largely
NB:
the blue was the hardest to remove, tough stuff that readily clogged the lower grit papers so that's why I started with the 80grit, the orange was also tough but once I touched the primer it cut away very easily, the red was childs play to sand off.... half a dozen swipes and it fell away easily.
The dark green stripe is coming off quite easily aswell, as did the old name
luckily the green carried through under the 'splash of colors' so once I had them off I went straight down to 180grit paper and took off the primer
once the primer was gone and the green fully revealed I changed down to 320grit paper.
although it isn't perfect color-wise the finish is ultra smooth and ready for my touch of bling
<img src="<>/wink.gif" alt="wink" title="wink" height="15" width="15" />![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/003_zps8f607f9b.jpg)
The main reason I did this was ....
1/
had a couple of large chips in the leading edges that needed filling
2/
the glass was actually worn right through at the front where its been dragged up on the sand over the years, again in need of filling
3/
it will tie in with what I'm doing for the short-term
repairs
to the main and foredeck (the rear decks will be replaced as they are completely shagged)
now I know I said earlier that I was going to cut / scarf in some new bits ply...... but I decided against that for a couple of reasons.
1/
time restraints: after I'd cut the first bit I figured this was going to take ages and I wanted a simple solid quick fix, simply because I won't know what's going in there until I tear the decks off in the off season.... the rot may be far worse than I know about at the moment
2/
strength issue: scarfing in is the traditional method BUT it lacks some strength, there was also the problem of curving the ply to better suit the hull shape, that meant time being spent of pre-curving the replacement ply aswell as the scarfing.
So I decided to do something an old sailor from way back when taught me at a regatta when my old mozzie was damaged....
a hole from a another mozzie just after the morning race was fixed during lunch and I was back on the water for the afternoon races, although the fresh resin was covered by that trusty old best friend..... gaffa tape
cut a ply plate that's just a bit bigger than the hole
bang a staple right in the middle of the plate then remove the staple
thread a fine wire through the 2 holes left by the staple
coat the ply plate in resin and slip into the hole
slip in a short dowel and twitch the wire around it then twitch the dowel so it pulls the plate up against the hull
with the remaining resin add sawdust till its like play-dough in its consistency
trowel the mix into the 'cavity'
let it set..... sand back .... paint as required or if needed
now I've used this old trick many times over, even Jurassic Karp has a few dabs of this in in, specifically where the old stringer slots were.
Its as light as you want it to be, use balsa-wood / cedar / pine etc.
Want it a bit heavier then use harder woods or as I've found plywood itself saved from the band saw works a treat
the big advantage is the strength, all the fine chips of sawdust are not all spread out but mixed up and tightly compacted. It sets super fast and can be sanded easily, I laid it down on Sunday with 7day resin, it was sanded back Monday night, micro filled on Tuesday night and finished tonight.
The process could have been done far quicker had I used a rapid set resin, the whole job would have been done in less than ~4hours
As it stands now, I have structural strength WITH a ply backing plate, the repair can easily be finished off once the decks are removed ..... flap disk on the 4
grinder,
grind" off the ply backing plate, add resin and cloth.... all done
the dark patches are the sawdust/resin mix
happy with the end result, it smoothed out really well and the microballon filler made it a perfect flush finish
centreboard case's are next on the agenda.....
Hi Kingy,
I'm thinking that the centreboards that came with Twice Shy were not the original ones. Back in them days the old mozzies had wide boards. <img src="<>/blush.gif" alt="blush" title="blush" height="15" width="15" />
Check where the cases are positioned relative to the rules. I'm guessing that they are well forward and probably vertical relative to the deck.
If thats the case then you could angle the boards back by putting fibreglassed wedged foam blocks into the case and angle them according to the rule limits. It's a quick fix and may improve the old girls handling. <img src="<>/cool.gif" alt="cool" title="cool" height="15" width="15" />
The difference in measurements between 1740 and 1182 are huge, and even with the cedar added to 1182's case its still 60mm further forward than 1740's..... measured from the front beam to the front of the board case.
At D.Y.C. today and I had a look at Al's boat 'Scorpion' and he has a block aswell only his has been placed at the back of the slot pushing the boards as far forwards as possible, his slots are even longer than 1182's.... I ended up with just under ~40mm long cedar packer and Al's would have to be nearer to 55mm of packer.
I'd have to agree that the boards themselves are not designed to run with the setup on the boat although the style and length is from that era as I remember it (recall seeing the dual timber boards and thinking how good they looked when I was moving from jnr-snr sailor), as to what happened with 1182's is anyone's guess....
My first mozzie STINGA #245 had a wide long board and the rudders were narrow and long comparison, much like 1182's are. I remember making a new set of blades that were shorter and wider and could be pushed far further forward under the boat than the old ones to get a better turning boat on the tacks, I also remember cutting off a couple of inches from the width and the length was also cut down on those boards once the rudder mods had been proven to work.
the rudders that came with 1182 are the same in their shape and style in that they are also long and not that wide. but as to what / where / & when the changes were made..... ??????????????????????????????
40mmx24mm cedar packer in place....
Jurassic Karp hangin around in the background.... <img src="<>/frown.gif" alt="frown" title="frown" height="15" width="15" />
once the boat is flipped back over I'll trim and fill the stub so its flush with the old deck, it will get more work when the decks are replaced in winter.
trimmed.... and filled <img src="<>/wink.gif" alt="wink" title="wink" height="15" width="15" />
the grey tape held the resin filler from running down the case slot and was easy to remove once the resin filler had gone off
After some thought and considerations, I decided that even tho Jurassic Karp's boards are ~200mm shorter, I'd only take off 150mm from Twice Shy's boards.
Main reason for this was Jurassics aren't tapered where-as Twice Shy's are, so I calculated out the actual surface area and ended up with a trim of 150mm being required.
these will be an easy re-shaping of the cut <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
the tough bit will be the slight slimming of the boards, just a tad tight to slide up n down in the cases....
27/525
i wouldnt be measuring from the front beam to the cases unless you have measured that the beams are in the same place as all the measurments for the beams and board cases are taken from the bow of the boat.
I've re-checked the measurements against the plans I have that came with Jurassic Karp, the measurements for everything else are within a couple of millimetres of the specs and compare well with Karp, its only the cases that aren't at the specs.
~100mm further forward than they should be even tho they are the wide case slots.
With the ~40mm packer I'm still forward of where it should be by about 60mm.
- 4,778 Online
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/KGrHqMOKowFJLbPgp8MBSVL4Z2Ew60_57_zps6f3f5e56.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/T2eC16ZHJIMFHJ11vhTuBSVL32g-960_57_zpscaa15d63.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/KGrHqQOKp0FJFT3e-GBSVL2Rig60_57_zps52b80044.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/T2eC16ZHJGsFFMf7CjEBSVL3TOJQ60_57_zps76f0c4f9.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/001_zps5ccf7486.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/003_zps488e2870.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/018_zps1062e991.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/019_zpsf6c44c49.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/013_zpseb025f21.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/014_zpsadf5a97c.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/015_zps6e9d1007.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/016_zps27225055.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/006_zpsd0149323.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/021_zps9584c003.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/022_zps7ad7247a.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/024_zpsbfe47b92.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/025_zpsc0ff1045.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/026_zps4a953b96.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/027_zps61a65720.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/001_zps53e0f810.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/002_zpsdb2f4b2e.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/003_zps682aca6d.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/001_zps2c3b962f.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/002_zpsfa12710c.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/006_zps6454d464.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/001_zps5e5dbb02.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/002_zps08b9e400.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/001_zps6d33f08f.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/002_zps34b2cf63.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/001_zps6ce31804.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/003_zps14e04aaa.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/005_zps6b3590de.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/006_zps67ccd2af.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/009_zps97ad69a9.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/015_zps50baf683.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/013_zpse8e161c4.jpg)
![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/1182/017_zps207310c5.jpg)
