Aluminum or Carbon?
Although weight is one factor that determines performance, more important factors are profile (ie tear drop vs air foil vs round) and bend characteristics. With that considered, a given alum mast may actually have superior performance to a given carbon mast. If profile and bend characteristics are equal, a lighter carbon mast would certainly be desirable. Carbon allows more flexibility when engineer bend characteristics since the cloth and thickness can be varied along the spar. But then the factors of cost must come in. Also, aluminum masts are generally lower maintenance and more durable. So the alum v carbon is not necessarily clear cut. I don't know specifically why nacra is switching, but I bet cost is a big factor.
Eric is right... it comes down to cost. All the new F17s delivered this year were with the SW Mast. Carbon mast is an option.
As for Performance, Bob Curry tested the new rig for six or seven months, with help from Bill Gillespie & Mark Batchelor
Looking at the NA Results for the top four boats. 1st. & 2nd. Placed F17s were with the aluminum mast... 3rd & 4th place boards had carbon rigs. all these boats had 1st., 2nd., & 3rd place finishes.
Note of interest, the 4th place F17 was a totally stock 2002 F17 with a four year old frt. end spinnaker.
Consensus in the Class, the SW Rig has the same performance as the expensive carbon rig
Regards
To help answer the question...
At the NAs, the carbon mast boat was first to A mark 75% of the time or more. At the finish, it really came down to who was sailing the boat as it ought to! Cost has been the biggest contributing factor in the switch to aluminum. The carbon mast was just getting out of reach in pricing. You really have to applaud Nacra for identifying the problem and finding a great solution.
Bob <img src=
BTW, I sail the Super Wing aluminum mast.
- 4,548 Online
