2-Part Urethane Foam to repair soft spots?
I have an '83 Prindle 16 and the inner side of the port hull from the center of the tramp forward is pretty much a giant soft spot. I was going to use thickened west systems until I discovered the full extent of the soft spot. I have done a good bit of work with composited before and I was thinking of just using a 3 or 4-lb density A B Urethane foam and just inject it similar to how its done with west systems, the only reason I don't want to use west is because of the cost associated with that product :-O . What do you guys and gals think?
standard polyester resin(bondo/3m brand 30$ gallon) works fine for injection. 2 part foam can expand way too much and do more damage than good, it also absorbs water and gets heavier as time passes. injection repairs can be rock solid and last a long time so don't be afraid!
2 ways to do this, you can either take tramp off, separate hulls by removing beams so that you can place hull soft side up and level, which takes a lot more time, or flip entire P16 on its side soft side up and level, leaning it against some sort of support, (tree, side of house), tape delaminated area off with masking tape, and use product as suggested by coastrat. One word of caution, do whatever it takes to make sure you break through outer skin only when drilling holes, penetrating through inner layer just causes all sorts of problems and delays and wastes much resin. 2nd method much quicker and you can be up and sailing again in a couple of days.
- 3,321 Online
