6:1 mainsheet on H14?
Thanks for the needed info on the rudder tubes Dan - much appreciated.
I have a new question for setting up the mainsheet blocks. Is 6:1 using 5/16 line (like on the H16) overdoing it for the H14?
It will actually work out cheaper than new 3/8 line and 5:1 blocks.
Roger
Posted : March 30, 2009 8:44 am
the heavier the line... the easier to hold... but the heavier line also takes more work to get through the blocks.. its a trade off...
some people "taper" their line (strip the outer jacket off the part of the line that goes through the blocks)... but this requires WHIPPING (sewing the line in place) or you could ruin the line as the jacket pulls off the core (at the worst possible time)
Posted : March 30, 2009 11:37 am
Forum Information
- 3,073 Online
Our newest member: TooTallTom
Latest Post: Hobie pearl / tiger mast needed
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
