81 GCAT 5.0 Rebuild
6 Users
(@rockypointbob)
[#6292]
Finally got the hulls back from repair and repaint...they look great.
So now I'm into the next phase of this project, which is to reattach the cross beams to the hulls. As I rebuild the boat, I want to replace all the hardware. I have the original assembly manual, which provides me the bolt lengths but it doesn't provide the diameter(s) or strength/type. Anyone know what I need to attach the three cross beams and best source to purchase? I do have all the back-up bars and beam inserts.
One other point...in the assembly manual it talks about "compression tubes"; what are these and should they be replaced and if yes, are they obtainable?
Any other considerations I should be aware of regarding installing the beams?
Thanks!
Edited by rockypointbob on Sep 05, 2017 - 11:23 PM.
Posted : September 5, 2017 6:29 pm
(@jsb4g)
Hi Bob, I sent you a reply email regarding your other questions. What page of the manual are you referring to? I will answer the rest of your questions with precise measurements in a week or so, including the stainless crossbeam bolts.
Posted : September 6, 2017 2:12 am
These are tubes that surround the beam bolts
they fit snug (top to bottom) and prevent you from over torquing down your beam bolts and sqwashing the beam down. they also can help to add rigidity/stiffness to your boat - and the stiffer the better.
Optimally they are made out of alum to avoid any corrosion with the beam
i have seen gcats with pvc... hardly optimal but better than nothing (i guess)
Posted : September 6, 2017 2:21 am
Pics or it never happened! 🙂
(@rockypointbob)
It happened....finally.
https://www.thebeachcats.com/pictures?g2_itemId=128943
Edited by rockypointbob on Sep 06, 2017 - 07:18 AM.
Posted : September 6, 2017 3:17 am
(@rockypointbob)
jsb4g wrote: Hi Bob, I sent you a reply email regarding your other questions. What page of the manual are you referring to? I will answer the rest of your questions with precise measurements in a week or so, including the stainless crossbeam bolts.
My copy of the manual doesn't have page numbers......it's the "Assembly Manual and Parts List".
I received your email with the other information, gracias!
Posted : September 6, 2017 3:22 am
(@rockypointbob)
Ok, so if I bought some stock to fit the bolt diameter I could cut it down to size as needed?
Posted : September 6, 2017 3:24 am
Yes! that's what i have - some regular stock cut to size
Posted : September 6, 2017 3:41 am
(@rockypointbob)
So from everything I could find on the subject, seems the proper bolt diameter/type for the cross beams is 1/4"x20 316 stainless steel. Sound about right?
I'm also needing to replace the screws for the rudder mounts through which the rudder pin passes, top and bottom. They look like a type of self-tapping metal screw. Are these specifically for fiberglass?
Here's a pic
Edited by rockypointbob on Sep 11, 2017 - 07:23 AM.
Posted : September 11, 2017 3:18 am
(@rockypointbob)
The other thing I was wondering about regarding the rudder system...
As I was looking at pics on Hans' facebook site, I stumbled across one of a rudder system on what could be a 5.0. I noticed something that was way different than on my system. Here's the pic from Hans site..
Do you notice anything different from the rudder pic from my boat?
Here's a better pic of mine
The rudder mounting flanges (or tabs) through which the rudder pins pass are not mounted WITHIN the rudder mounts but rather OUTSIDE the rudder mounts. The top flange is below the mount and the bottom flange is resting on the top of the lower mount. This doesn't seem right to me. I'm thinking an owner from way back must have taken the rudder system apart to repair hull damage and then screwed up when they reassembled it.
Thoughts?
Posted : September 11, 2017 3:29 am
I THINK they should be bolted
self tapping screws wouldn't be my choice
without access ports - i wouldn't know exactly how to address this
rockypointbob wrote: So from everything I could find on the subject, seems the proper bolt diameter/type for the cross beams is 1/4"x20 316 stainless steel. Sound about right?
I'm also needing to replace the screws for the rudder mounts through which the rudder pin passes, top and bottom. They look like a type of self-tapping metal screw. Are these specifically for fiberglass?I
Here's a pic
Posted : September 11, 2017 8:07 am
The current setup defiantly not optimal and i highly doubt "stock"
my GUESS would be there was damage to the transom and they felt it was easier / better to move the gudgeons vs fixing it correctly/optimally.
IF there are self tapping screws, that adds to my belief of damage... as through bolting and backing plates would be a MUCH stronger solution but without access (i.e. during actual production or ports) it would be a much larger job to gain access.
Posted : September 11, 2017 8:21 am
(@jsb4g)
Agreed. I have seen this numerous times...transom damage followed by remounting like this because the original spot is destroyed. It is a quick fix in lieu of a proper repair. My boat had a transom job and the way it was done is to cut inspection ports in the rear deck, rebuild transoms, place against the interior of the transom a piece of water treated/sealed 2x4 cut to the shape of the transom and predrilled to match the holes in the transom for the rudder mount (though you could use a stainless plate- custom made- for the same purpose), then secure rudder mounts with bolts, washers, and stop nuts. The wood (or stainless) plate distributes the weight across the entire transom, thereby reducing pressure on the spots where the mounts attach. My wooden plates are starting to get old and weakened by water, so I will soon be replacing them with stainless plates. I have a metal fabricator in town that will make me plates using the wood as a template.
The first of your two photos is the correct way to mount the rudders. I would NOT use self-tapping screws. Stainless bolts/washers/stop nuts.
MN3 wrote: The current setup defiantly not optimal and i highly doubt "stock"
Edited by jsb4g on Sep 12, 2017 - 11:59 AM.
Posted : September 12, 2017 5:55 am
(@rockypointbob)
When I had the hulls refinished, I had the body guy build up the transoms so they should be pretty sturdy now. Looking at the pic (which I got from Hans FB site) I posted of the correct mounting of the gudgeons, it appears they also used SS sheet metal screws for the brackets.
I have inspection ports on both hulls but they are too far forward to reach the transom. I've had the boat out with the rudders mounted incorrectly (I had no idea at the time) and it worked great, but what do I know, it was my first time solo on a boat! So I guess the answer is to have two more ports installed such that we can do backing plates. Bummer.
What about the Dotan kick-up rudder system? Guess I would have the same issue with mounting?
Posted : September 12, 2017 6:07 pm
(@rockypointbob)
Here's another rebuild question: The finish on the cross beams and mast is pretty beat up. What's the best way to clean them up? Is painting an option....bad idea?
Posted : September 12, 2017 6:09 pm
(@Anonymous 32247)
I had good success using the Awlgrip system on all of my aluminum on This End Up. Steps were to sand the anodizing, use their wash coat, next up was the 545 epoxy primer, then used the Awlgrip 2000. Paint is never going to be as durable as anodizing, but there are very few places to get a mast anodized.
I am very satisfied with the appearance and the durability of this finish system. It was a lot of work though for a DIY project. If you are using professionals they likely could work through this pretty quickly. Me not so much.
Here is the album on the aluminum work on my project:
https://www.thebeachcats.com/pictures?g2_itemId=123176
Posted : September 12, 2017 6:22 pm
from what i have read, most people who try Dotan's on beach cats are not happy with the results
I still highly doubt it - that is not the correct screw for this application and i find it unlikely they are sheet metal screws - more like number ss philips heads with nylocks behind them, probably a ss backing plate of some type
this is a crazy high stress area of the boat, and when rudders hit bottom (happens more than you think) self tapping screws could rip right out of fiberglass
Posted : September 13, 2017 3:02 am
the more i think of this, the more i think it is ok how it is
i am no engineer but i think the sheer forces would not be changed by this set up, or if they are changed it isn't by much
i am certain self tapping is not the correct solution
adding ports is not optimal nor fun work
i think i would leave it as is
hopefully one of our engineers on here will comment too
Posted : September 13, 2017 3:34 am
(@jsb4g)
rockypointbob wrote: When I had the hulls refinished, I had the body guy build up the transoms so they should be pretty sturdy now. Looking at the pic (which I got from Hans FB site) I posted of the correct mounting of the gudgeons, it appears they also used SS sheet metal screws for the brackets.
I don't know anything about the Dotan system. I defer to MN3 re sheet metal screws vs bolts. It makes sense that bolts would be better. As for leaving as is, since repairing it correctly is a major undertaking, you could just leave it as is, but remember this thread if you encounter issues later. Lastly, I will be going sailing this weekend, so I will be able to measure any parts you want measured. I remember you wanted the rudder pin length and diameter measured. I am using clevis pins right now, but I have the original long rudder pins too. Was there anything else?
Posted : September 14, 2017 1:50 am
(@rockypointbob)
jsb4g wrote: [quote=rockypointbob]When I had the hulls refinished, I had the body guy build up the transoms so they should be pretty sturdy now. Looking at the pic (which I got from Hans FB site) I posted of the correct mounting of the gudgeons, it appears they also used SS sheet metal screws for the brackets.
I'm actually headed down to Mexico this weekend so I'll be able to finally see all the parts, take measurements, etc. But thanks much for the info on the traveler car; got it in today. I guess I will leave the rudders as is for now and until I actually get to the point of flying a hull, which will probably not be anytime soon. :-O Actually, there is one thing that would be most helpful...some good pics of your jib rigging. I feel pretty confident with rebuilding the mainsheet rigging but not so much with the jib. I've seen some pic of a Gcat 5.0 barber-haul set up but they weren't very clear. Thanks!
Posted : September 14, 2017 5:27 pm
(@rockypointbob)
I'm actually headed down to Mexico this weekend so I'll be able to finally see all the parts, take measurements, etc. But thanks much for the info on the traveler car; got it in today. I guess I will leave the rudders as is for now and until I actually get to the point of flying a hull, which will probably not be anytime soon. :-O Actually, there is one thing that would be most helpful...some good pics of your jib rigging. I feel pretty confident with rebuilding the mainsheet rigging but not so much with the jib. I've seen some pic of a Gcat 5.0 barber-haul set up but they weren't very clear. Thank You!
Posted : September 14, 2017 5:33 pm
(@rockypointbob)
MN3 wrote: the more i think of this, the more i think it is ok how it is
I think I'm going to go with it as it is since I've sailed it twice and seemed to be ok...at least for now.
Posted : September 14, 2017 5:35 pm
just cause it didn't explode the last 2 times doesn't mean it won't
you should really deeply inspect and test it, wiggle it (just a little bit) - jk - wiggle it a decent amount
and keep an eye on it (inspect it a few times) under sail
the forces get much bigger with speed - i think i read the tension of the rigging doubles every 7 knots (or something like that)
I'm not 100% sure that the casting resting on the gudgeon doesn't increase shear ... so please look a little deeper than my advice alone - i would feel bad if you rip your transom off hitting ground or surf (and it was due to my best guess)
Posted : September 14, 2017 5:46 pm
(@rockypointbob)
dmgbear55 wrote: I had good success using the Awlgrip system on all of my aluminum on This End Up. Steps were to sand the anodizing, use their wash coat, next up was the 545 epoxy primer, then used the Awlgrip 2000. Paint is never going to be as durable as anodizing, but there are very few places to get a mast anodized.
Wow. That does look like a major project! But the end result is great. I think I will get everything else squared away then leave that for last....or buy a new boat!
Posted : September 14, 2017 5:55 pm
(@rockypointbob)
Will do. Once I get her back together, I'll wiggle it around then take her for a slow spin and watch if it flexes. etc. So there should already be a SS backing plate installed when the hull was put together? I wonder how others have repaired problems with the mounts without an inspection port.
Posted : September 14, 2017 6:11 pm
(@Anonymous 32247)
Or buy another old boat. I am now a year into a J30 monohull. Things I learned on the 5.2 apply to this new project too. None of this stuff is simple or easy. I like researching techniques and other people's experiences and then figuring out what I want to do. Resources like beachcats.com are invaluable to those of us taking a little different course.
I wish I could say that recycling an old boat like This End Up is the green thing to do, but all the overspray in my shop says otherwise. But my Nacra 5.2 looks almost as good as any boat fresh off the showroom floor, maybe better with those killer tangerine sails and dark blue hulls. The experience from all these guys watching this site is key to getting to a great final result.
One of these days soon my woodshop will be back to being a woodshop rather than a boat shop, but that will happen when it happens. Fooling around with boats is keeping my back in pain, my arms in pain, my wallet in pain, god I love this stuff.
Posted : September 14, 2017 6:21 pm
(@jsb4g)
I don't think the boat was built with a backing plate. If there had been one, this would not be such a common problem. My biggest concern would be your screws coming loose over time and you not noticing
Posted : September 15, 2017 2:01 am
Unknown -
i looked at hanz's current 5.0 and it has no real access via his 4" access ports - who knows
a. the accepted their fate and added a port (it's not THAT hard - but like everything, there is skill involved so it's easy to have issues if you never have done it before)
b. did invasive surgery (i.e. remove a section of the transom to add the plate and then reattached it)
anything can be "repaired" - just a question of funds, time and desire
c. smathered 5200 (or epoxy, or something) everywhere in an attempt to secure the gudgeon on the external section - which may or maynot last depending how strong it is and what forces it meets
Posted : September 15, 2017 3:58 am
(@klozhald)
dmgbear55 wrote: I wish I could say that recycling an old boat like This End Up is the green thing to do, but all the overspray in my shop says otherwise.
It is green because you can repair it to usability, and doing so consumes less material than you would if you scrapped it and bought another, A huge part of sustainability is getting away from disposable attitudes in all things.
Dmgbear you are more sustainable than you give yourself credit for.
Posted : September 15, 2017 7:15 am
+1
and most of that overspray will live in your shop (walls and ceilings, and more) forever! never seeing a dump - well played sir!
Posted : September 15, 2017 9:49 am
Page 1 / 2
