Batten Question for Boomless
I have two long battens that came with the G-Cat 5.7 main that fit on the bottom slot.
One is standard (like the others) 1" width and the other is about 2" width.
Which is the preferred Batten width for the bottom batten on this boomless Main?
This is a Supersail standard OEM sail for a 28' mast.
Thanks!
Posted : September 12, 2021 2:41 am
Not sure if this relates, but the Nacra 6.0 uses a heavier bottom batten in heavy air and is also boomless. With
the large jib in heavy air the main gets back winded and partially inverts. They call this the main sail Hula. The heavier batten is supposed to minimize this.
Posted : September 12, 2021 6:06 am
Forum Information
- 2,981 Online
Our newest member: TooTallTom
Latest Post: Hobie pearl / tiger mast needed
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
