Cell phone app for ...
Cell phone app for GPS tracking/mapping?
11 Users
(@ramstadt)
[#4791]
I have a really old handheld GPS unit and would prefer not to take it on the boat because it is just one more thing that I need to worry about. I'm looking at using either my smart phone or my ham radio to record my path when I go out for a sail. My cell phone would be the most convenient of the two devices. The radio is fantastic, but getting data back out of it is more cumbersome.
Is anybody using an Android phone to record their track for the day? If so, what app are you using?
Posted : November 7, 2014 5:32 am
(@rcgaston)
http://www.raceqs.com/
Posted : November 7, 2014 8:12 am
Andres Chianale
(@Andinista)
The problem is the battery duration with the GPS on. It will work maybe for half an hour, but you also want your phone for safety.
Posted : November 8, 2014 9:56 am
Andres Chianale
(@Andinista)
The other problem is that you can't really manipulate it if from the wire. I have troubles even to watch the speed
Posted : November 8, 2014 10:01 am
(@ramstadt)
Not interested in manipulating while on the water. I was just interested in getting tracking data that I can look at after the fact. Not sure how much battery the GPS uses on its own. I know running a GPS app eats up battery, but part of that is due to the fact that it keeps the screen on.
For now, I think I'll just collect GPS data in my ham radio and download to my computer when I get home. The ham radio is less of a safety tool although it would be 3rd after the marine radio and the cell phone if I got into trouble.
Posted : November 8, 2014 5:37 pm
(@hobiefred)
For just recording your track, RaceQs works very well. The best thing is that it matches your tracks with others recorded at the same time and location, so you can have race replays, etc.
The best part is that it uses very little battery power. I'm able to turn it on before I leave the beach and it is still recording when I get back, some 6 hours later. It then automatically uploads the data to the server the next time your connected to wifi.
If you want to watch your spead while you sail I like the Speed puck the best, since I can mount it under the bridle wire/forestay and watch my spead as I also watch my jib, bridle vain, and where i'm going.
Posted : November 9, 2014 12:43 am
Andres Chianale
(@Andinista)
It's nice to monitor your speed, that's the manipulation I mean, just grabbing the phone to watch the screen. Theoretically you can see the effects of your adjustments so you can learn to better sail your boat. After using iRegatta a few times, I realized that real time speed is the most interesting to me. Angle to the wind too, but it's better to watch that later on your track records. On the water the app can figure out the wind direction as the average between tacks, but it's not reliable, wind is not constant enough and if you want to adjust it often you end up caring more about the app than sailing.. like wassap versus real life..
So in my experience:
- Phone in a case hanging from your neck sucks, totally useless if you are on the wire. If your crew can take it and tell you the speed from time to time it's better than nothing, but in general it defies simplicity, it's just one more thing to worry about.
- Phone in your tramp bag recording your tracks for a while, could be, every once in a while. Doing it every time also defies simplicity. Just remember to turn the app off before it eats all the battery. Or have a second emergency phone on the tramp bag or with you.
- A watch that can show the speed, sounds like a good idea to me. Haven't found the budget yet. I think they can record tracks too. That's all you really need, isn't it? A more sophisticated use could be nice but the required conditions are non realistic: you need a reliable wind direction estimation that doesn't require you to sail for the app rather than for fun. They might be useful for longer navigation, but you would need a car battery.. They also have regatta features, and info, like laylines, estimated time to start line, etc., but you either sail the boat or manipulate the app.. if you can see the screen at all despite sunlight and water.
Posted : November 9, 2014 1:25 am
http://gps.motionx.com/ works great
i used if for years
now all my battery is needed to broadcast bluetooth to my EcoXGear EcoXBT radio
Posted : November 10, 2014 5:12 am
(@marekli)
MN3 wrote:http://gps.motionx.com/ works great
i used if for years
Curious why MotionX app would save on battery? you still need to have GPS radio on your phone turned on to get signal...
Also wondering what your battery life time is with bluetooth transmitting to your ecogear box. I have been looing at the GoalZero rockout2 box that's also solar rechargeable....but maybe not as waterproof.
Posted : November 10, 2014 5:43 am
(@ramstadt)
MotionX is for iPhone. That doesn't help me because I have an Android phone.
Forgive me for being an engineer, but it seems to me that a GPS radio on its own shouldn't be a huge drain on the battery. I have an old handheld hiking GPS that runs a very long time on 2 AA batteries. I have a ham radio that has a GPS and broadcasts my location to the amateur radio APRS network. Neither one seems to suffer from receiving GPS signals from satellites.
Transmitting radios such as wifi, bluetooth and cellular protocols will use up battery. The backlight on the screen will use tons of battery. The CPU if very busy will eat up battery.
So, if the app is trying to transmit the data or display real-time maps on the screen, then I can understand how the battery will be consumed. I was just hoping that somebody offered a data logger that would allow me to access the information after I got back to dry land.
Posted : November 10, 2014 6:04 am
gps used up loads of battery on my iphone when i used it - but no where's near as much as my bluetooth radio
Posted : November 10, 2014 8:56 am
Correct, GPS is a passive, receive only device,(R only is a huge advantage because it means unlimited numbers of simultaneous users, with no loss of signal).
However 2 AA cells are quite a bit bigger than most phone batteries, therefore the phone suffers.
I looked into various phone options, & decided that a Garmin 76CX, (that included a removable non device locked chip with all the marine charts for the Great Lakes), for a measly $150 on sale, was a way better idea than my phone. It runs about 16hrs on 2 AA, can store 99 trips, & can overlay them on Google Earth.
I can also use it on the Stinkpots.
Posted : November 10, 2014 9:51 am
(@johnes)
ramstadt wrote: I have a really old handheld GPS unit and would prefer not to take it on the boat because it is just one more thing that I need to worry about.
I don't see how a GPS is going to get in the way or be something to worry about..... I just put mine in a double zip lock freezer bag, turn it on, set to track, and then stow it in my tramp bag..... When I get back on shore I just retrieve it and load the track to my computer when I get home... Been doing this with the same GPS (Garmin GPSMAP 96C) for years, have never had a problem, and the batteries are pretty cheap...
Edchris177 wrote: It runs about 16hrs on 2 AA, can store 99 trips, & can overlay them on Google Earth.
I have often wanted to do this, but never took the time to figure it it out....
Can you give us briefing or point me to where I can learn how to do this?
Edited by JohnES on Nov 10, 2014 - 04:10 PM.
Posted : November 10, 2014 10:06 am
André
(@catmodding)
ramstadt wrote: MotionX is for iPhone. That doesn't help me because I have an Android phone.
Late in this season I downloaded " The FastTrack " its a free app available
in playstore.
Its a complete app for android, build for navigation/racing, has a timer. and so
many more features including a tracker. If you have micro-sd slot on you're
device there's even the possibility to download maps and navigate on
the android device.
Used it on my last sailing-trip, its great! But its almost winter here so no
more testing.
So I downloaded some charts and tested it in my car, its very promising .
Here's a link https://play.google.com/store/apps/details?id=com.nautka.thefasttrack&hl=nl
And here's a link to the developpers website. http://nautkaapps.wordpress.com
I'm planning to do some longer(camping) trips next summer.
Thinking of using this app on a 10" android tablet and put it in
a waterproof bag together with a couple of usb power banks .
Grtz, André
Posted : November 11, 2014 2:31 pm
André
(@catmodding)
in playstore.
the android device.
more testing.
Grtz, André
Posted : November 11, 2014 2:33 pm
André
(@catmodding)
Twice?? don't know how I did this 🙁 🙁 🙁
Posted : November 11, 2014 2:44 pm
(@ramstadt)
Thanks. I'll take a look. Winter is not as severe here. So, there will be some days of sailing through the winter. There could be more if I go out and buy some warmer gear.
Edited by ramstadt on Nov 12, 2014 - 09:03 AM.
Posted : November 12, 2014 5:01 am
(@kbcatman)
Try an app called EarthNC. Makes your phone like a little chart plotter. Probably not what you want to be staring at while driving the cat, but I've used it on a variety of boats like my F-27. Means you can a device in hand to take pics and video and check your progress/position/speed/direction etc.
Posted : January 4, 2015 7:16 am
André
(@catmodding)
Had a look at EarthNC and it looks very promising, but is not a free app.
Also had a look at the reviews on this app, it seems it sometimes
"freezes" since the latest update and does not work on all android
devices.
Will do a little investigation if nooa charts are suitable for the FastTrack
app.
These charts are free to download, but only cover the US.
So, not for me. Edit. I mean the nooa charts.
André
kbcatman wrote: Try an app called EarthNC. Makes your phone like a little chart plotter. Probably not what you want to be staring at while driving the cat, but I've used it on a variety of boats like my F-27. Means you can a device in hand to take pics and video and check your progress/position/speed/direction etc.
Edited by catmodding on Jan 05, 2015 - 03:03 AM.
Posted : January 4, 2015 9:10 am
(@kbcatman)
I haven't experienced any issues with it at all. I have a Samsung s III on 4.4.2.
Posted : January 4, 2015 12:21 pm
 spfx
(@spfx)
The one I use most and have had the longest is Motion X GPS. It does no good for Android users, but since we're on the subject... It has many nice features, but will drain my battery in less than 5 hrs as long as I'm not looking at it often.
One feature it doesn't have is knowing your speed throughout your track as you review it on a map. I more recently discovered Speed Tracker and its available for all makes of smartphones free version too ( I can speak for $3.99 version only). It will display a color range you define as it plots your track. I usually export via email, but it may have other options as well as format type. I believe map choices are limited to street and there's no option to download maps, meaning you need to stay data connected to your provider eating more battery.
Battery life- Smartphones have so much going on at any given time they cannot outlast handheld dedicated GPS units even if you shutdown power draining sources IMHO. Two AA alkaline batts have more capacity than my iPhone 5S by a large margin. A larger format phone should last an entire 8-10hr day I'm guessing.
Features to consider:
- nautical chart ability
- download and cache map of operating area
- speed information viewed graphically on mapped tracks
- exporting ease and format
- a setting for interval tracking at some selectable time interval would save a huge amount of battery
- nautical units of measure
- top speed, avg speed, etc.
- audible updates of selectable info
- VMG, time to waypoint,waypoint heading, layline
- features to conserve power
Apologies for getting off your intended question.
Edited by spfx on Jan 05, 2015 - 10:19 PM.
Posted : January 5, 2015 6:19 pm
