Convert Jib to furling jib?
Don't forget the tack of your jib is on the front cross tube on the 5.7. The furling drum is above the apex of the bridal so you'll have to visit your sailmaker and loose a small amount of sail area. Have you considered a hanked on jib? I know some of you guys will groan at this idea but it's a good alternative if you're not racing. You won't notice any difference in performance and it'll be easy up and easy down. With the 5.7's front tramp good at dockside too. The enemy of your jib is flogging and you want to raise it quickly and last thing. A zippered luff is a pain and a furler is great but expensive especially with a sail modification.
Don't do it! I forgot to mention in my earlier post that as well as shortening the luff of your jib considerably because the tack is well below the apex of the bridal, the sheeting angle will be changed, the sailmaker will have to change the angle of the foot of your jib to keep your jib blocks in the same place otherwise your sheeting angle will be all wrong. Not to mention your jib has battens which will have to be removed or altered and I suspect the jib is quite old and prone to leech flutter. Someone please correct me if I'm wrong on all this.
- 3,562 Online
