Gooseneck Clevis Pi...
Gooseneck Clevis Pin
yurdle
(@yurdle)
[#76]
Hi
Where can I find a replacement clevis pin for the gooseneck on my Prindle 18? Its 1/4" x 1-1/2", which I believe is also the same for all prindles.
Thanks for any advice,
SR
Posted : November 24, 2007 4:37 pm
Depends on where you are located. That's a pretty common item, should be available at any marine store, or catamaran dealer. Fill out your profile (click the profile link in the main menu) and folks can help you better.
Posted : November 25, 2007 7:25 am
(@sunjammers-com)
Most dealers should have something that will work, like Damon said, where are you located?
Posted : November 25, 2007 1:14 pm
(@captainkirk)
In a bind on any of the Prindle Cats and the Nacras with booms, They all use the box between the boom and attachment point on the mast. A 1 1/2" X 1/4/20 HEX head bolt works fine with a nylock nut. I would normally take one of the pins out and replace it with a bolt to not lose the box.
Kirk Newkirk
Posted : November 26, 2007 12:57 pm
