H18 Trailer Roller replacement
how about PVC, for a H18 you would need 12" - 16" diameter PVC, 2'long, cut length in half, so you have 2 pieces, then split those 2 pieces in half leaving you with 4 half-moon hull cradles. Attach to trailer using lag-bolts, bolts with a shallow concaved head, once attached to trailer cover bolt heads with silicone and then glue carpet to the inside of the PVC, carpet covers bolt heads and allows for sliding surface when wet. No more metal parts to gouge your gel-coat
PVC in different thicknesses can be obtained at your local plumber supply store>
Found some good threads in the Hobie forum that "Idahosailer" posted on the PVC idea. He even heated the PVC in his oven (slowly and at I think about 210F) to soften them and then put them on the upside down hull to form fit. Covered in indoor/outdoor carpet.
I tried to find 10" PVC with no luck at local stores. Only option was to buy a 20' piece for a lot of cash. Just decided to buy the trailer cradles from Hobie for $170. Use these on front and rollers in the rear.
Call plumbers around your area... i got 4 feet of 10" FREE 😎
edited by: presto99, Jul 29, 2010 - 05:15 PM
CatSass wrote: I'd like to replace the rollers on my H18's trailer with something more Cat friendly, maybe 2x6's covered wtih astroturf? Got any better ideas?
TIA
KK
Actually with a Hobie 18 even the single rollers are not a problem, unless you are planning on allowing snow to acumulate!
But upgrading your single rollers to doubles will nicely spread the load and also make loading unloading easier.
Here is a pic of mine, I have them front and back.
The trailer to my red boat had the full length carpet covered 2x10's. I loved that trailer. It also had full length 2x4's for guides. Sailors were always sitting on them as they make a perfect park bench at the regattas when the boat is off the trailer.
Now the real beauty . . . you did not tie the boat down. just limiter straps to prevent forward/aft movement.
Hi All
Thanks for the info. I like the idea of double rollers, are they from the trailer company? (I haven't a clue who made my trailer, there aren't any stickers as far as I can see).No problem with snow accumulation here in Tallawhacky.
There is some "repaired" PO damage to one of the hulls right above the rollers, so I want to do something. I'm leaning toward the 2x8 or 10 with carpet idea so far. Pics would be great!
KK
- 1,116 Online
