Harken Carbo Ratcha...
Harken Carbo Ratchamatic
9 Users
(@traphappy)
[#6059]
Word to the wise, don't drop a Harken Ratchmatic (spinnaker sheet block) in the sand.... That said, does anyone have an idea of how to fix one after doing so? Mine is stuck in the locked position. Fine when there is a breeze, but not so good in really light stuff. I've tried washing it, boiling it, bouncing it hard on a carpeted floor. Have not taken it apart. Hope this experience helps others avoid perils of letting sand get into sensitive, but otherwise really good equipment...
Posted : May 27, 2017 4:48 pm
(@martyr)
I deleted my comment because it was irrelevant. 😎
Edited by martyr on May 28, 2017 - 05:16 PM.
Posted : May 27, 2017 7:14 pm
(@tamumpower)
Eh I've gotten mine salty and grungy before and just let them soak and repeatedly tried to activate them until they worked.
Posted : May 27, 2017 7:59 pm
(@klozhald)
Put it in a bucket of clean water. While you are watching the screen (TV, movie, Youtube) gently and constantly swirl the part in the water until it begins to move. This could take hours.
Can you even disassemble it? Is it bolted together, not using peened rivets?
Posted : May 29, 2017 10:04 am
(@nacra55)
Have you tried adjusting the tension on the auto ratchet? There's a hole where you can adjust it with an allen wrench. Maybe loosen it before soaking?
Posted : May 29, 2017 1:34 pm
(@samc99us)
Dawn dish detergent. Soak in a bucket with water + dawn = cured. Usually. They can occasionally fail.
Posted : May 29, 2017 3:59 pm
I know they say when they bind up to soak in almost boiling water (not boiling) to dissolve salt crystals
not sure about sand
They have very good support at Harken
If all else fails, call them and tell them they have locked up - they will probably tell you to send it in for repair / replacement
Posted : May 30, 2017 2:04 am
(@davefarmer)
I second Ron's advice on adjusting the tensioning mechanism with the Allen wrench, while soaking and spinning. Might dislodge the grains that are jamming things up.
Posted : May 31, 2017 10:43 am
leeboweffect
(@leeboweffect)
I had one on my MacGregor 25. When it would get rough (never actually had it lock up) I would put it in a bucket (with a tight sealing lid) of water with a little Dawn dish detergent then put the bucket in my car. After a week or so of soaking and joy riding (agitation) it would be like new after a fresh water rinse to get out the soap.
Posted : May 31, 2017 11:39 am
(@traphappy)
I was not sure how much broad interest this question would have so I hesitated to ask it. Turns out, you guys gave lots of great advice. I really appreciate it, and will go through the list to try to fix my block. It's back on the boat on the beach now, so I won't have report for another two weeks though. Just got done cleaning and putting together the Harken cams from the mast rotation system. They were full of sand (I bought the boat recently). That was a very satisfying experience, first time doing that. Quick instant gratification with that small project. Thanks!
Posted : May 31, 2017 2:34 pm
