Help for sticky cam...
Help for sticky cam blocks
Larry Smith
(@lawrencer2003)
[#921]
All,
The cam blocks on my Harken 8:1 downhaul are sticky so of course they are not doing a great job and downhaul gets loose. Any suggestions on reviving them? Lubricants? Cautions when disassembling?
Posted : September 24, 2009 6:43 am
(@pm)
This is going to sound overly simple or condescending, but, use high pressure water, and manually exercise/pivot each cleat. That should do it. Also check that the screw going down the center of each cleat is not over tightened (compressed and binding) the cleat from pivoting.
IMO, do NOT use lubricants.
Posted : September 24, 2009 8:16 am
cam blocks or cleats?
sticky or sticking?
if sticking i agree with Philip,
if sticky, stop lubricating with honey.
if blocks, (although this is more for main blocks) you may need to remove and soak in ultra hot water (not boiling) and soak and repeat. this can free up salts built up..
Posted : September 24, 2009 8:46 am
(@pm)
To clarify, when I said cleat, I meant cam cleat, as in
http://www.harkenstore.com/uniface.urd/scpdinw1.showProd?B4RPMEB9Y8VKMG
Posted : September 24, 2009 8:53 am
I agree, you will only make it easier for lines to slip out.. there are no bearings to lube here.. only a single strip of metal that acts as a spring
Posted : September 24, 2009 10:09 am
Larry Smith
(@lawrencer2003)
mummp wrote: To clarify, when I said cleat, I meant cam cleat, as in
Yep..Struggled with calling them cleats or blocks. Looks like I just need to clean and adjust. Thanks
Posted : September 27, 2009 5:09 am
