Help to find Rudder yoke
I have a nice fibre hiking stick but I can't use it because the yoke bolt broke.
It is for a Hobie 16, but the standard yoke is much wider and the cool stick won't fit the standard yoke. This one is pretty much 2cm square (smaller than stock). I have no idea about the stick, it has no markings. Will I have to get a yoke fabricated ?
I have searched around, found some 'standard', which I am sure is not what this is. Thanks
It is welded in there, but I could try with a drill press if I can find one to use. The hiking stick rather than being a tube that fits inside the yoke, has ears that fit over the outside of the yoke. I can make the ears fit over a standard yoke, but the design of the ears only allows the stick to be perpendicular to the ground to about 60 degrees, when of course I need 90 degrees.
The hiking stick company must have had these made up. Here is the underneath pic
- 1,822 Online
