Hobie 16 Mast Rotation
My hobie 16 mast only rotates the way it is supposed to on 1 tack, not the other. Rig tension is normal, and I loosened it some more to be sure. Have not dropped the mast yet but maybe a deformed mast base or step? What else? Very strange, just strated doing it. Seems to almost want to counter rotate to the opposite side position
an h16 mast is not hard to step or drop
i wouldn't sail it again until the issue is discover and corrected
you either have an obstruction in your system or something is preventing it from rotating that shouldn't.
this could lead to catastrophic failure of the weakest link (shroud or mast) when enough pressure (wind) is applied
There is a bend, but it was there before I was having problems. Although I guess a bend can get worse. Not sure I would call it significant although that’s the eye of the beholder. Anyone in North Florida have a nice Non Comptip 16 mast for sale? I’m having some rudder problems as well, might be new used boat time
Edited by jalex on Apr 30, 2019 - 10:25 AM.
What do you mean by “only rotates the way it is supposed to on one tack?”
Does that mean it won’t physically rotate (like it’s binding)? Or that it won’t rotate on it’s own, but can be physically pushed over and then stays there? Or it can be pushed over but then when the mainsheet tension is released it counter-rotates?
A bend in the mast could certainly be a contributor, but there could be other things going on as well.
- 346 K Posts
- 2,549 Online
- 31.2 K Members
