Hobie 16 Super Jib ...
Hobie 16 Super Jib Battens - Installation
2 Users
(@lambini)
[#4527]
I have the original jib on my 1984 Hobie 16. The battens were hinged, one hinge broke, and I couldn't find replacement hinges. So, I bought a set of Super Battens to replace them. The original battens were tied, but these just have blunt capped ends. How do I install Super Battens properly? 😕
Posted : June 14, 2014 1:07 pm
(@fxloop)
What i did with mine is drill you two small holes, about 1/8" diameter ( just large enough to get the string through ) about a inch apart towards the end of the batten that's sticking out with the white cap, then lace them as you would a regular batten and tie off. You don't have to get them super super tight, just snug where there's no chance they'll fall out. They work great btw!!
Posted : June 15, 2014 5:36 am
(@lambini)
Thanks Tim! When I ordered them, I didn't realize they had to be modified, so was a little confused.
Posted : June 18, 2014 1:44 am
