Wrong Cat Trax?
Hey,
Bought a 8'6 Cat Trax ( http://www.murrays.com/13-1401.html) to use with my Prindle 16.
Looks like it's the wrong size for the prindle? The Catamaran rubs both tires, hence no movement...Am I doing something wrong? I guess I can drill new holes on the dolly and mount the tires closer together.
Thanks.
Posted : June 11, 2014 9:24 am
according to the description there should be a second hole for 8' beams
"Cat Trax axles are available in 8' or 8'6" lengths and the appropriate axle length for your boat will be shipped. The longer 8'6", 2" outside diameter, anodized aluminum axle is double-drilled to accommodate either 8' or 8'6" wide cats."
Posted : June 11, 2014 10:29 am
Forum Information
- 754 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
