Hobie 18 daggerboard sleeve
I am in the process of sealing the hulls on my H18 in prep for the trip to Catalina.Does anyone know what the material is in the strong-back on either side of the dagger sleeve\tunnel? seem's to have buckled slightly.
I am planing on using vacuum to suck the epoxy into the mounting holes for the rear crossbar anybody done this?
Hey Damon, if you reach inside the hull you can feel a strong-back on both sides of the dagger sleeve.
I am sealing the bolt holes that hold the rear beam on...in the hull\on the lip, they leak.Also going over the whole boat to eliminate leaks.
Carl
Edited by onekiwi on Nov 04, 2014 - 08:45 AM.
The sides of the daggerboard trunk (inside the hull) are fiberglass/foam sandwich construction like the rest of the hull. On some years, the foam piece is just a narrow strip and on other years it is almost as wide as the whole trunk. If you cracked/buckled the trunk, you're going to need to reinforce it with fiberglass cloth and resin.
- 1,659 Online
