Hobie 18 Top
injecting resin is the "standard" way to handle the soft spots. You can contact a pro for advice or repair. I allways send people to jeremy@surfcitycatamarans.com
Homepage: http://www.surfcitycatamarans.com
I found injecting did not work as the injection fell into the hull. The holes drilled were done proper. Soooooo. I am stubborn and want to get it right...flipped the hulls upside down and did an inverted injection to the soft spots and taped them so the epoxy would not drip out. It worked very nicely and the soft spots are very firm and solid with very little weight added to the hulls. This is the work of no Lubber 😉
mh_jenkins wrote: I found injecting did not work as the injection fell into the hull. The holes drilled were done proper. Soooooo. I am stubborn and want to get it right...flipped the hulls upside down and did an inverted injection to the soft spots and taped them so the epoxy would not drip out. It worked very nicely and the soft spots are very firm and solid with very little weight added to the hulls. This is the work of no Lubber 😉
I am a newbie, but I injected it myself and as long as you don't drill through the second layer of fiberglass the Get-Rot will push itself out the air holes that you drill. You then tap over the air holes and it will push a little further back. I had great sucess with it! This is my first season of Cat sailing and I have fallen in love with my boat!
- 723 Online
