Jib line snagging
Edchris177 wrote: Do you have a preventer?
Run a piece of 1/4" bungee from the outside of the front beam-through the bottom of the diamond wires-over to the far side of the beam.
That will deflect the jib blocks/sheet away from the mast base/cleat
+1 Had 18' Prindle with same issues. An extra piece of trap bungee solved the problem.
Posted : July 3, 2016 6:11 am
If you have a mast rotator, the jib sheet might still get snagged with the preventer rigged as shown in the picture submitted by Edchris. I solved this by running the ends of the bungee forward and outboard to the the bridle foil tangs. You can make a simple attachment using using small diameter line looped around the tang and add plastic clips to the bungee ends.
Posted : July 4, 2016 7:06 am
Forum Information
- 1,224 Online
Our newest member: nacrainter18
Latest Post: NACRA Inter 17R / F17 Rigging help
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
