Nacra 5.2 broken mast
Hello There,
I'm new here and I live in Germany. Here I am sailing on a lake in Bavaria a Skippi 650 Cruiser and a Nacra 5.2. In a storm a few weeks ago my mast is broken. Now I could get a mast of a Hobie 18, I want to build on my Nacra 5.2. The dimensions are almost identical. What do you all mean? Is this possible?
Thanks for your opinions.
Greetings from Bavaria
Jens
Posted : July 27, 2015 8:10 am
If the length is right and you can get the bottom casting to fit I can't see a reason it wouldn't work. You may have to reposition the rigging hounds (brackets) to match your rigging though. And if the casting doesn't fit you may need to convert over to a hobie mast step.
Posted : July 27, 2015 9:22 am
Forum Information
- 1,611 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
