Nacra 5.2 Forward deck removal
Technical Help
1
Posts
1
Users
0
Reactions
2,376
Views
Today I started the task of repairing a small crack in the hull of my Nacra 5.2. After just a little bit of sanding it became very apparent that the damage was extensive enough that for the repair to be strong I would have to work from inside the hull. Because the damage was forward of the front crossbar I decided the best way to access the hull was to remove the deck. I had never done this before but figured the hull was so bad I could not possibly make it any worse.
I started with a 5 inch hammer head Red Devil putty knife and a hammer and about 45 minutes later the deck was off.
Edited by swaompfox on Sep 20, 2015 - 04:27 PM.
Posted : September 20, 2015 10:17 am
Forum Information
- 1,173 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
