Plugging & redrilling Hobie rudders
Technical Help
4
Posts
4
Users
0
Reactions
2,555
Views
Hobie sells a metal template that fits on all Hobie rudders and has the exact place to drill or redrill for Hobie rudders and the holes are very close. H-16 rudders with adjustable upper castings are drilled different than H-16 rudders without adjustable upper castings and so on. Your local Hobie dealer should have one of these. I bought one for myself years ago and was happy that I did and so are my friends.
Posted : May 28, 2009 9:16 am
Bare in mind that resin will not stick to plastic. On my G-Cat rudder holes I taped one side and carefully located the center of the enlarged hole. Wrapped plastic tape around a dowel of the right size, held it in place, and poured the resin around it. When it hardened the dowel came out easily and the hole was perfect.
Posted : May 30, 2009 3:09 pm
Forum Information
- 636 Online
Our newest member: wqaz
Latest Post: Hobie pearl / tiger mast needed
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
