Raise My Trailer Ro...
Raise My Trailer Rollers
[#97]
I would like to get more clearance under my Hobie 18 by raising the double rollers in relation to the trailer frame.
I have these double rollers on each corner, attached with U-bolts. Anyone have ideas and steer me to the correct pieces to add/change? Even a couple of inches would help a lot.
Posted : February 5, 2008 11:00 am
Garret
(@Garret)
Newby Registered
Can you weld? Do you have a drill press and large vise?
edited by: Garret, Feb 06, 2008 - 12:31 AM
Posted : February 5, 2008 1:30 pm
Garret wrote: Can you weld?
I don't know, I've never tried it. 😀
Garret wrote: Do you have a drill press and large vise?
Yes
I've been looking for a source for simple taller brackets that are holding the center of the double rollers that I could swap in, with no luck.
Posted : February 5, 2008 7:45 pm
(@dsltrc)
best bet is to take the whole thing to a trailer company (or any fabrication shop)... they will have the know how and the tools to make what you want...
Posted : February 6, 2008 6:15 am
Culley
(@turtlecat)
Dont know if I'm to late to comment on this one but what the heck. I have the same rollers and padded them with carplet for non marking reasons, and prevent chipping the boat on close metal. That small amount in height worked well. If its complete height your after the 2 brackets that hold the roller assy. to frame can be elongated by simple welds. Cost less than a Franklin in my part of the world (assuming 2 assy.) Dont forget Muffler shops do great welding...CHEAPLY.
Posted : March 5, 2008 7:37 pm
(@Anonymous 5115)
get longer u bolts and put some blocks in there
Posted : March 8, 2008 10:16 am
