Recoating carbon mast
Just did this last year.
Here is a link to to the thread on the project.... I went with Interlux two part using a roll and tip application. But, as a test I did a carbon fiber 20" X 20" layup and painted it with the Interlux Brightsides. Did this to see how it would hold up to the sun etc... I will say if I had to do it over again I would have went with the Brightsides. When working a two part once it starts to kick off you got work fast if you’re not using a sprayer. If you using a sprayer….use lots of protection…that is get the professional stuff and make sure your neighbors are cool with it.
http://www.thebeachcats.com/forums/viewtopic/topic/12293
Shoot me a PM if you would like some pix
A local shop sells a spray epoxy paint. It actually has 2 parts, you have to break a seal on the bottom then shake and spray. The cans are tinted to whatever color you want. It turned out very nice on a boat transom we are working on, its not cheap though at $20 a can. Does anyone know about this stuff? Longevity?
Johnes, That looks very nice. I would like to go with a black mast. I wish there was a decent way to get the beams black but I will leave them as is.
- 616 Online
