Running a dyneema l...
Running a dyneema line through dolphin striker eyelet
7 Users
(@martin_langhoff)
[#5879]
Sailing a Whisper cat, I need to run a dyneema line that gives strength to the spinnaker pole through the eyelets of two dolphin strikers,
These dolphin strikers are wing-shaped (elongated, length-wise), about two inches long. The piece is carbon fiber, but the eyelet is in a plastic part... the hole is way too narrow for the line, and the line needs to go through around 2 inches.
I've tried very wide masking tape, pushing, pulling, screaming... 🙂 what's your best trick?
Posted : February 9, 2017 10:18 am
(@windwardde)
Anyway to "marry" the line to a wire, like using an electric snake?
Posted : February 9, 2017 10:26 am
(@nacra55)
Picture? I'm lost with your description.
Taper the line then tape it so you have a point that progresses to the full diameter?
Posted : February 9, 2017 11:08 am
(@klozhald)
Gotta have photos to understand this one.
Posted : February 9, 2017 12:21 pm
snaking a wire w a hook is your friend
Posted : February 9, 2017 1:15 pm
(@Anonymous 32247)
Could also use air pressure if you have it, to blow the line through and/or use the shop vac to pull it through. This is how electricians get their lead through long conduits.
Posted : February 9, 2017 1:22 pm
(@gahamby)
If the hole is to narrow for the line perhaps a thinner line or a larger hole is in order.What are the diameters of the line and holes?
If it's just a tight fit situation, the suggestion of tapering the line and using a length of bailing wire inserted into the line is how I would do it. Bend a small hook into the end of the wire and push the wire into the line. Some soap as a pulling lubricant might also help. Good luck, GH
Posted : February 10, 2017 5:22 am
