Shroud Tension
generally they don't stretch but break, so any broken strands replace the shroud
when they fail big time it is often due to corrosion down in the fitting so have a good look in there for any white furry stuff
many say to replace the shrouds every year or 2
a lot will depend on where you are sailing, light winds in a small lake that would seem overkill
big winds and crossing out to an outshore island with 20 year old rigging probably a very bad idea
think also that the hobie 14 used to race with really loose shrouds, so loose the mast would threaten to come off unless it was tied down
hobie14 a strange little beast, might be best to find out more about it on a hobie specific forum
Posted : May 25, 2009 6:13 pm
Forum Information
- 2,213 Online
Our newest member: wqaz
Latest Post: Hobie pearl / tiger mast needed
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
