Soft Spot
1 Users
(@kwshag)
[#3208]
Hi All,
Question - I am getting ready to repair a soft spot on my hull just in front of my tramp. I am planning on using the west marine system but I am wondering about weather or not I need the 205 or 206 hardner, is the 206 stronger since the cure time is longer? Also, do I need the filler at all? Whats the best technique to get the epoxy to spread around to the entire area? Do you drill all the fill holes first or as you go?
West System 105 Epoxy Resin
West System 205 or 206 Epoxy Hardener
West System High Density 404 Filler
KW
Posted : August 11, 2012 6:02 pm
