Spinnaker Question
Technical Help
2
Posts
2
Users
0
Reactions
2,223
Views
My understanding is that to use a symetrical spinnaker you need to move the spinnaker pole (whisker pole) from one side to the other depending on which tack you are on. The advantage of the asymetrical spinnaker is that you can have a stationary pole. This is why you always see asymetrical spinnakers on cats as a movable whisker pole is not really feasible. The A's are also nice because you can point much higher with them than a symmetric spin.
You may be able to get a sailmaker to recut your regular chute to an asymetrical configuration, you would have to talk to one.
Posted : October 9, 2009 6:27 pm
Forum Information
- 1,306 Online
Our newest member: TooTallTom
Latest Post: Hobie pearl / tiger mast needed
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
