Traapeze (Help)
Measure your shroud line and subtract 1 1/2 to 2 1/2 feet, should be close. Better to short than to long. If you are going to use any on the fly trap adjustment blocks you need to allow for the length of those blocks. Remember that as you move to the front the line will get closer to the deck.
Murrays has them. Single http://www.murrays.com/mm5/merchant.mvc?Screen=PROD&Product_Code=02-6253-0&Category_Code=C-R-R&Store_Code=MS
double http://www.murrays.com/mm5/merchant.mvc?Screen=PROD&Product_Code=02-6263-0&Category_Code=C-R-R&Store_Code=MS
edited by: skarr1, May 26, 2009 - 03:48 PM
Posted : May 26, 2009 10:40 am
Forum Information
- 3,252 Online
Our newest member: wqaz
Latest Post: Hobie pearl / tiger mast needed
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
